Kiwi Ears x HBB Punch in-ear monitors feature a 1DD+2BA+2EST design. This configuration delivers impactful bass, balanced mids and extended highs for a rich listening experience across the entire frequency band. Harmony between the different drivers is made possible by a passive 3-way crossover for a coherent, tonally pleasing sound. As you can see, the Punch drivers live up to their name, with a frequency response curve that emphasizes bass, while delivering rich, detailed highs. Their 12-ohm impedance and 98dB sensitivity make the Kiwi Ears x HBB Punch relatively easy to drive. In addition, they come with a detachable 0.78mm CIEM cable to 3.5mm jack termination for a high level of compatibility.
The Punch's Ø10mm composite dynamic driver provides an impressive 15dB bass boost for the most impactful sound. The overall sound is deep and immersive.
The midrange is handled by two Balanced Armature drivers, carefully tuned by Kiwi Ears to deliver a balanced midrange with roundness and clarity.
Two electrostatic drivers extend the frequency response of the Punch up to 40kHz for detailed, subtle, but no less natural treble.
Product type | In-ear monitors |
Configuration | 1x Dynamic driver (1DD) 2x Balanced Armature drivers (2BA) 2x Electrostatic drivers (2EST) |
Sensitivity | 98dB (±1dB) @ 1kHz |
Frequency response | 5Hz-40kHz |
Crossover | 3-way |
Impedance | 12Ω |
Detachable cable | |
Earphone connectors | CIEM 0.78mm 2 pins |
Cable end connector | Jack 3.5mm |
Cable conductor material | Copper |
Cable cross-section | 0.518mm² (20AWG) |
Cable diameter | 1.45mm |
Package | 1x Kiwi Ears X HBB Punch in-ear monitors 1x Detachable cable CIEM 0.78mm to 3.5mm jack termination |
Color | Black |
Impedance (Ω) | 12 |
Efficiency / Sensitivity (dB) | 98.0 |
Wireless | No |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
