By buying this product you get 39 loyalty points
33 and 45 RPM Ortofon OM-10E Black
Triangle offers a beautiful manual vinyl turntable with belt drive. This one has been specifically developed by the famous Pro-Ject brand and allows the playback of 33 and 45 rpm records. Its straight aluminum arm and its low vibration motor ensure a smooth and flawless playback. The arm as well as the Ortofon 0M-10E cell are pre-set for a quick and easy installation. The turntable comes with a Pro-Ject Connect It E RCA cable with HP-OFC copper conductors and gold-plated connectors.
| Specifications | |
| Product type | Vinyle turntable |
| Turntable type | Manual |
| Drive type | Belt |
| Arm type | Straight |
| Arm material | Aluminum |
| Arm length | 21.8cm |
| Effective mass of the arm | 8g |
| Overhang | 22mm |
| Cartridge | Ortofon 0M-10E |
| Output voltage of the cartridge | 4mV (1000Hz, 5cm/sec) |
| Frequency reponse | 20Hz - 25kHz |
| Pressure force | 1.25 - 1.75g (12.5 - 17.5mN) |
| Reading angle | 20° |
| RCA cable | Pro-ject Connect It E (copper conductors, gold plated contacts) |
| General | |
| Dimensions | 420 x 112 x 330mm |
| Weight | 4kg |
| Color | Black |
