Letshuoer's Cadenza 4 are hybrid in-ear earphones featuring a dynamic driver with a beryllium-plated membrane and three balanced armature drivers. The design of these earphones has been entirely conceived around this specific feature, resulting in high-quality reproduction that combines rich sound with astounding precision.
Cadenza 4 earphones feature a brand-new dynamic driver with a 10 mm diameter beryllium-plated diaphragm. This diaphragm is characterized by its thinness and high rigidity. This considerably improves response speed, making the earphone easier to drive while reducing non-linear distortion. The result is a more natural sound and a fuller reproduction of low frequencies.
Cadenza 4 earphones are also equipped with 2 Sonion drivers and a Knowles balanced armature driver coupled with a surgically precise crossover filter. These additions enhance tonal density, enrich midrange detail and extend the treble frequency range. The combination of these 3 balanced armature drivers delivers a sound reproduction as delicate as it is transparent.
Cadenza 4 earphones adopt a solution involving 3 acoustic tubes coupled to a 4-channel electronic crossover. With its cutting-edge 50μm 3D-printed acoustic tubes, Letshuoer has ensured that they are calibrated to recreate a faithful, smooth and balanced sound. The four-channel electronic crossover allows precise control of frequency distribution and considerably reduces phase errors.
The Cadenza 4 earphones are the opportunity for a new collaboration between Letshuoer and HeyGear Technology to refine the chassis. The body of the earphones is precisely calibrated to ensure long-term wearing comfort. The front plate is made of CNC-machined aluminum alloy with a matt finish, giving a textured handfeel.
The earphones come with a cable made of 392 strands of pure silver-plated single-crystal copper, offering optimum conductivity combined with minimal signal loss. Furthermore, the cable comes with 3 interchangeable jack connectors (2.5mm / 3.5mm / 4.4mm) for maximum device compatibility.
Type of product | In-Ear Monitors (IEM) |
Type of drivers | 1x Dynamic driver 3x Balanced armature drivers |
Headphone connectors | CIEM 0.78mm 2 pins |
Cable connector | Jack 2,5mm / 3,5mm / 4,4mm |
Frequency response | 20Hz - 40kHz |
Impedance | 15Ω |
Sensitivity | 102dB |
Cable length | 1.2m |
Color | Silver |
Package | 1x Pair of Letshuoer Cadenza 4 earphones 1x 1.2m 0.78mm 2-pin CIEM cable 3x Modular jack connector 6x Pairs of ear tips 1x Storage pocket |
Color | Silver |
Impedance (Ω) | 15 |
Efficiency / Sensitivity (dB) | 102.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 40000 |
Wireless | No |
Cable termination | Jack 4.4mm |
Cable termination | Jack 3.5mm |
Cable termination | Jack 2.5mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
