MOONDROP ARIA 2 In-Ear Monitors Grey
The latest advances in Moondrop product technology are at the heart of the latest addition to the Aria series! Indeed, Moondrop's Aria 2 headphones adopt the dynamic transducer and magnetic circuit design that have made the brand so successful. However, the Aria 2 not only retains the technological basis of Moondrop's flagship products, but also combines it with a newly designed brass cavity allowing, among other things, easy replacement of the ear-tips if required, and the integration of a pressure vent to boost low frequencies.
Reference : 18832
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 30-10-2026.
MOONDROP ARIA 2 In-Ear Monitors IEM Dynamic 122dB 33 Ohm 16Hz-22kHz Grey
MOONDROP ARIA 2 In-Ear Monitors IEM Dynamic 122dB 33 Ohm 16Hz-22kHz : Front and back view
The latest advances in Moondrop product technology are at the heart of the latest addition to the Aria series! Indeed, Moondrop's Aria 2 in-ear monitors adopt the dynamic transducer and magnetic circuit design that have made the brand so successful. However, the Aria 2 not only retains the technological basis of Moondrop's flagship products, but also combines it with a newly designed brass cavity allowing, among other things, easy replacement of the ear-tips if required, and the integration of a pressure vent to boost low frequencies.
Moondrop Aria 2 : Brand-new ceramic-coated spherical dome composite diaphragm.
Aria 2 in-ear earphones feature an all-new composite membrane with titanium nitride coating.The two-step processing of three materials achieves a smooth treble response surpassing that of a metal-coated diaphragm, and ultra-low distortion performance that is lower than that of other crystalline-coated diaphragms. It delivers excellent treble detail and extension without any granularity or roughness.
Moondrop Aria 2 : Replaceable acoustic nozzle.
Aria2 incorporates a new generation of replaceable acoustic filters. The front end of the brass nozzle consists of a removable tip, allowing users to replace the acoustic filter quickly and conveniently. Replacement is far easier compared with existing multi-layer filters, and the design makes for greater reliability. In the event of blockage or damage, the cost of replacement is much lower than that of standard nozzles.
MOONDROP ARIA 2 In-Ear Monitors IEM Dynamic 122dB 33 Ohm 16Hz-22kHz: Replaceable acoustic nozzle
Product typeIn-Ear Monitors IEM
Speaker driver typeDynamic
Connector2 pins 0.78mm
Impedance33 Ohm @1kHz
Sensitivity122dB/Vrms @1kHz
Frequency response16Hz - 22kHz
Total harmonic distortion (THD)≤0.05% @1kHz
Package1x Moondrop Aria 2
1x Earphone Cables
12x Eartips
1x Storage Case
1x User Manual
ColorSilver
Impedance (Ω)33
Efficiency / Sensitivity (dB)122.0
Lowest frequency (Hz)16
Highest frequency (Hz)22000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
The latest advances in Moondrop product technology are at the heart of the latest addition to the Aria series! Indeed, Moondrop's Aria 2...
