CRINEAR NIGHTFALL In-Ear Earphones
New
The CrinEar Nightfall are in-ear earphones based on a Multi-Dynamic Monolithic (MDM) architecture, which directly integrates the drivers and acoustic channels into a single machined shell. Their dual 10 mm and 8 mm dynamic drivers combine natural reproduction with controlled bass, offering a balanced and slightly warm signature.
Reference : 22495
109,99 €tax incl.
91,66 € tax excl.
Shipping date: 10-11-2026.
CrinEar Nightfall Dynamic In-Ear IEM Earphones 104dB 9 Ohm 2Hz-38kHz Blue
CrinEar Nightfall: Front view
Designed for versatile listening, they combine precise mids, smooth highs and reinforced presence in the sub-bass, while keeping a compact format suited to extended sessions. Their Midnight Blue anodized aluminum shell adopts an architecture derived from the Project Monolith concept, transposing this design approach into a model intended for everyday use.
CrinEar Nightfall: A monolithic acoustic architecture
The CrinEar Nightfall are based on the Multi-Dynamic Monolithic (MDM) platform, whose internal acoustic structure is directly machined into the shell. This design eliminates traditional tubes and modular chambers in order to integrate the drivers and acoustic channels within a single assembly, thereby promoting better coherence and more consistent control across the entire spectrum.
CrinEar Nightfall: Interior view
CrinEar Nightfall: A balanced and versatile reproduction
Their tuning, developed from recent acoustic research, aims for a balanced and natural reproduction with a targeted presence in the sub-bass and a slight overall warmth. The bass remains controlled without dominating the other registers, while the mids retain a precise and realistic reproduction; the highs, for their part, favor smoothness without darkening the reproduction. This signature allows the Nightfall to adapt to many musical styles and listening preferences.
CrinEar Nightfall: Frequency response
CrinEar Nightfall: Dual dynamic drivers
CrinEar Nightfall: Exclusive dual dynamic drivers
The acoustic section relies on two proprietary dynamic drivers, designed by Kingtone exclusively for CrinEar. The 10 mm driver covers most of the spectrum and establishes the foundation of the reproduction, while the 8 mm model acts as a bass control system to precisely shape its response. Both having been developed for the MDM platform, their integration favors a homogeneous signature rather than a segmented presentation of the registers.
CrinEar Nightfall: A compact aluminum shell
The Nightfall shell is precision-machined from a block of aluminum, then coated with a Midnight Blue anodization that enhances its durability while keeping a contained mass. The MDM architecture allows the external volume to be reduced to a minimum, making the Nightfall the most compact earphones ever designed by CrinEar. This design facilitates prolonged wear, while maintaining the rigidity required by their monolithic acoustic structure.
Product typeIn-ear earphones
Frequency response2Hz-38kHz
Impedance9Ω @1kHz
Sensitivity104 dB/mW @1kHz
Drivers1x Dynamic Ø10mm
1x Dynamic Ø8mm
Cable terminationJack 3.5mm
Jack 4.4mm
Earphone connectorsCIEM 0.78mm 2 pins
Cable conductor materialSilver-plated copper
ColorBlue
Package1x CrinEar Nightfall
1x Earphone cable
1x Jack 3.5mm termination
1x Jack 4.4mm termination
7x Pair of in-ear tips
1x Storage pouch
ColorBlue
Impedance (Ω)9
Efficiency / Sensitivity (dB)104.0
WirelessNo
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
CRINEAR NIGHTFALL Dynamic In-Ear IEM Earphones 104dB 9 Ohm 2Hz-38kHz Blue
The CrinEar Nightfall are in-ear earphones based on a Multi-Dynamic Monolithic (MDM) architecture, which directly integrates the drivers and...
