With the Rays, Moondrop is presenting in-ear monitors with USB-C termination. These are based on a pair of drivers combining dynamic and planar magnetic technology to effectively cover the entire frequency band. The cable supplied incorporates a DSP allowing you to create your own custom equalisation, while an NPU chip and a specially-trained algorithm provide significant noise reduction while preserving human voices.
The Rays earphones use a hybrid two-driver configuration, combining a dynamic driver and a planar driver. This configuration covers an ultra-wide frequency range with very low distortion, improving the precision of the transient response and enabling finer spatial positioning.
The Rays come with a USB-C terminated cable so you can connect directly to all your equipment without the need for an external DAC. The USB connector also incorporates a DSP that rivals the quality of many audio interfaces, offering excellent resolution, a clear soundstage and impressive dynamics.
Thanks to the inclusion of DSP, Rays reproduction is highly customisable. You can create a fully customised equaliser via the Moondrop app available on Android and iOS or their website, and load it into your earphones, so you can always enjoy it without needing to use external services.
The audio chip used also incorporates a NPU (Neural Processing Unit) and combines it with an advanced ambient noise cancellation algorithm trained to recognise the human voice. As a result, these earphones offer impressive noise reduction while retaining voices perfectly, allowing you to make calls or play in noisy environments without worry.
In response to the demands of acoustic design, Moondrop uses a high-precision 3D printing process to achieve exceptionally fine control over the final shape of the cavity, guaranteeing a flawless listening experience combined with excellent wearing comfort.
The Rays were designed to be as close as possible to the VDSF curve, offering a natural sound reproduction.
Product type | In-ear monitors |
Drivers | 1x Dynamic driver Ø10mm 1x Planar magnetic driver Ø6mm |
Impedance | 18.5Ω ±15% @ 1kHz |
Sensitivity | 120dB @ 1kHz |
Frequency response | 7Hz-39kHz |
Total harmonic distortion more noise (THD+N) | ≤ 0.05% @ 1kHz |
Earphone connectors | 0.78mm 2pin |
Cable termination | USB-C |
Microphone | Yes |
Color | Green Purple |
Package | 1x Moondrop Rays USB-C cable 1x Storage case 3x Pairs of ear tips (S/M/L) |
Color | Violet |
Color | Green |
Impedance (Ω) | 30 |
Efficiency / Sensitivity (dB) | 120.0 |
Wireless | No |
Headphone / Earphone connector | CIEM |
Phone call feature | Yes |
Noise reduction | Yes |
