With the Bunny, Tanchjim offers in-ear earphones that are as affordable as they are qualitative. They feature a titanium-plated driver coupled with a double acoustic cavity specially designed to promote low-frequency vibration. The result is a sound reproduction with rich bass and precise highs, offering a wide soundstage.
Furthermore, the USB-C version of the Bunny also integrates a 24bit DAC, an amplifier stage and a DSP, opening up the possibility of customizing sound rendering thanks to a 5-band equalizer available via the Tanchjin app.
Tanchjim's Bunny earphones feature dynamic drivers with titanium-plated PET (polyethylene terephthalate) diaphragms and flexible suspension, delivering rich bass, clear vocals and a wide soundstage.
These drivers are complemented by a double acoustic chamber, offering more precise control over bass and midrange, while providing a harmonic distortion rate of 0.05% at 94dB.
Bunny earphones benefit from a labyrinth structure of their acoustic cavities, offering even more resonance to low frequencies for deeper, more dynamic sound reproduction.
The Bunny's internal cavity has been developed to minimize high-frequency absorption and sound dispersion, resulting in a clearer, more extended high-frequency response thanks to the improved linearity of the sound waves.
Bunny is supplied with a silver-plated OFC copper cable to ensure noise-free data transmission. A flexible transparent sheath encloses the cable, making it difficult to entangle.
The USB-C version of the Bunny also incorporates a two-chip 24bit DAC supporting a sampling rate of up to 96kHz. This version also includes a high-performance operational amplifier, as well as a DSP for furthermore precise control over the final sound output.
Thanks to the Bunny's built-in DSP, you can use the Tanchjim application available here to shape the sound of your earphones to your taste. To do this, you have access to 4 equalization presets and a 5-band equalizer, with the option of saving and sharing your sound profiles with other users.
| Specifications | |
| Product type | In-ear monitors (IEM) |
| Speakers type | Dynamic |
| Speakers technologie | DMT4 Ultra |
| Diaphragm | Titanium-plated PET (Polyethylene terephthalate) |
| Sensibility | 123dB |
| Impedance | 30Ω |
| Total harmonic distortion (THD) | 0.05% @ 1kHz 94dB |
| Frequency response | 8Hz-48kHz |
| Conductor material | Silver-plated OFC copper |
| Cable structure | Litz wires |
| Connector | 2 pins 0.78mm |
| General | |
| Color | Silver |
| Package | 1x Tanchjim Bunny Type-C 1x USB-C to 2-pin 0.78mm connector cable 1x Carrying pouch |
| Color | Silver |
| Impedance (Ω) | 30 |
| Efficiency / Sensitivity (dB) | 123.0 |
| Lowest frequency (Hz) | 8 |
| Highest frequency (Hz) | 48000 |
| Wireless | No |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | CIEM |
| Phone call feature | No |
| Noise reduction | No |
