TANCHJIM OLA II In-Ear Monitors IEM
The TANCHJIM OLA II are hybrid in-ear monitors combining a 10mm DMT 5 dynamic driver with a dual magnetic circuit and dual acoustic chamber with a PURE Hi balanced armature dedicated to very high frequencies, using a coaxial hybrid acoustic architecture that promotes coherent reproduction from bass to treble.
Reference : 22397
49,00 €tax incl.
40,83 € tax excl.
Shipping date: 01-12-2026.
Tanchjim OLA II 1DD+1BA In-Ear Monitors 3.5mm Jack Micro 30Ω 121dB 8Hz–48kHz
Tanchjim OLA II
The OLA II feature a total harmonic distortion of just 0.03% at 1kHz / 94dB, an impedance of 30 Ω ±10%, a sensitivity of 121dB/Vrms and an extended frequency response from 8Hz to 48kHz. Its internal acoustic chamber, optimized through simulation, promotes more accurate reproduction of transients and musical details, while its ergonomic design was developed using artificial ear data and more than 3000 ear-shape samples to optimize the nozzle angle, shell curvature, contact points and weight distribution. An external vent structure also helps limit pressure buildup.
The detachable cable uses silver-plated copper Litz conductors arranged in a twisted structure and connects to the earphones via 0.78mm 2-Pin connectors. The version equipped with an unbalanced 3.5mm jack connection also features a Goertek MEMS microphone designed to improve voice clarity during calls, online meetings, gaming sessions and voice communications.
The OLA II are therefore designed to provide detailed reproduction, low distortion and good coherence between different frequency ranges, while maintaining a format suitable for extended listening sessions.
Frequency response and packaging of the Tanchjim OLA II
Technical Specifications
Product TypeIn-Ear Monitors
Driver Type1DD DMT 5 Ø10mm + 1BA
Acoustic StructureCoaxial hybrid acoustic structure
THD0.03%@1kHz 94dB
Impedance30Ω ±10%
Sensitivity121dB/Vrms
Frequency Response8Hz–48kHz
Detachable Cable
Cable StructureSilver-plated copper Litz wire with a twisted structure
Earphone ConnectorsCIEM 0.78mm
Microphone
Cable Termination3.5mm Jack
ColorGray
Packaging1x Tanchjim OLA II IEM
1x Detachable CIEM 0.78mm cable with 3.5mm jack termination
6x Pairs of in-ear tips
1x Storage pouch
ColorGray
Impedance (Ω)30
Efficiency / Sensitivity (dB)121.0
WirelessNo
Cable terminationJack 3.5mm
Phone call featureYes
Noise reductionNo
TANCHJIM OLA II In-Ear Monitors IEM 1DD+1BA 3.5mm Jack Micro 30Ω 121dB 8Hz–48kHz
The TANCHJIM OLA II are hybrid in-ear monitors combining a 10mm DMT 5 dynamic driver with a dual magnetic circuit and dual acoustic chamber with a...
