By buying this product you get 30 loyalty points
Tanchjim SODA are high-quality hybrid in-ear monitors (IEMs) designed for demanding audiophiles seeking balanced, detailed, and comfortable sound reproduction. Featuring a multi-driver architecture of 1 DD + 4 BA + 2 passive units per ear (one DMT5 dynamic driver, four balanced armature drivers, and two Silk System units), it effectively covers the entire audio spectrum with depth, precision, and smoothness. The internal design is optimized with a high-precision 3-way HPFD-Seg crossover, ensuring consistent integration between the different drivers. The ergonomics have been designed for long listening sessions, with lightweight, contoured ear cups and a pressure reduction system. In terms of connectivity, the SODA comes with a detachable premium high-purity silver-plated copper cable with interchangeable 3.5mm single-ended and 4.4mm balanced terminations for maximum compatibility with any audio source.
At the heart of the Tanchjim SODA is a sophisticated hybrid configuration combining:
This unique combination delivers balanced, detail-rich sound while maintaining natural timbre and extended frequency response.
Tanchjim SODA headphones offer remarkable technical performance with an impedance of 15.5 Ω ± 15% and sensitivity of 120 dB/Vrms, making them easy to drive with a wide range of audio devices, from portable players to dedicated DACs/amplifiers. Their 8 Hz – 48 kHz frequency response ensures well-defined bass extension, clear mids, and open highs without listening fatigue, for accurate music reproduction across all genres.
The ergonomics of SODA have been carefully designed to offer optimal comfort even during long listening sessions. The compact, lightweight ear cups, combined with pressure-balancing T-APB ear tips, reduce pressure sensations in the ear canal. A patented pressure relief system helps minimize ear fatigue while ensuring a more stable fit and consistent audio performance.
SODA headphones come with a detachable, high-end silver-plated Litz copper cable, ensuring excellent conductivity and clean signal transmission. Thanks to the interchangeable connector system, you can easily switch between a 3.5mm single-ended connection and a 4.4mm balanced connection depending on your needs. The box also includes:
This complete set ensures a high-end listening experience from the very first use and easy integration into any portable or stationary audio setup.
| Specifications | |
| Product type | In-ear monitors (IEMs) |
| Configuration drivers | 1x 10mm dynamic driver 2x PURE Mid BA 2x PURE Hi BA 2x SS passive units |
| Dynamic driver technology | DMT5 |
| Diaphragm material | DLC Pu Surround composite dome diaphragm |
| THD | 0.5% (@1kHz 94dB) |
| Impedance | 15.5Ω (±15%) |
| Sensitivity | 120dB/Vrms |
| Frequency response | 8Hz-48kHz |
| Detachable cable | |
| IEM connectors | CIEM 0.78mm |
| Cable terminaison | Interchangeable: 4.4mm balanced angled jack & 3.5mm angled jack |
| Cable structure | High-purity silver-plated copper, densely braided coaxial Litz structure |
| General | |
| Color | Transparent / Blue |
| Package | 1x Pair of Tanchjim SODA IEMs 1x Detachable 0.78mm 2-pin cable 6x Pressure-balanced T-APB ear tips (6 pairs) 1x 3.5mm & 4.4mm connectors 1x PVC leather carrying case |
| Color | Blue |
| Color | Transparent |
| Impedance (Ω) | 15.5 |
| Efficiency / Sensitivity (dB) | 120.0 |
| Wireless | No |
| Cable termination | Jack 4.4mm |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | CIEM |
| Phone call feature | No |
| Noise reduction | No |
