TRUTHEAR PURE In-Ear Monitors
With the Pure, Truthear offers high-performance in-ear earphones, direct descendants of the Hexa. Like their predecessors, they are equipped with a combination of four drivers, combining dynamic and balanced armature technology to effectively cover the frequency range, offering balanced sound reproduction with natural timbre and exceptional precision.
Reference : 20988
89,90 €tax incl.
74,92 € tax excl.
Shipping date: 13-05-2026.
Truthear Pure In-Ear Monitors IEM Dynamic Balanced Armature 13.8 Ohm 124dB 7Hz-40kHz
Truthear Pure : Front view
With the Pure, Truthear offers high-performance in-ear monitors, direct descendants of the Hexa. Like their predecessors, they are equipped with a combination of four drivers, combining dynamic and balanced armature technology to effectively cover the frequency range, offering balanced sound reproduction with natural timbre and exceptional precision.
Truthear Pure: 4 driver combo
Like the Hexa, the Pure is based on a dynamic driver coupled with three balanced armature drivers. This hybrid configuration uses each technology to its fullest potential to provide effective coverage of the frequency band.
The low frequencies are therefore assigned to a 10mm dynamic driver with a sophisticated magnetic structure coupled with an LCP membrane and silica gel suspension. This model incorporates a copper voice coil specially developed for this purpose. Unlike the aluminium-plated copper coils traditionally used, this one has been designed to minimise its resonance frequency (FO) while increasing its impedance. The result is powerful bass that perfectly meets frequency response requirements.
Truthear Pure : Dynamic driver
A pair of composite balanced armature drivers are responsible for the midrange. These have been specially tuned to precisely complement the dynamic driver, while strictly conforming to HRTF characteristics.
Truthear Pure : Balanced armature driver
Finally, a custom balanced armature tweeter, with characteristics very similar to Knowles' WBFK series, is responsible for the high frequencies, not only effectively complementing the frequency range coverage, but also offering a refined and precise rendering of the treble.
Truthear Pure: Crossover by DLP 3D printing
The internal cavity of the Pure was machined using DLP (Digital Light Processing) 3D printing. This process enables a level of design finesse that would otherwise be impossible. Truthear was thus able to design a waveguide structure tailored to each driver, in order to merge their outputs into a coherent whole, as close as possible to the brand's desired sound reproduction.
Truthear Pure : Cross-sectional view of the composition of an earphone
Truthear Pure: Balanced sound profile
The Pure introduces numerous changes to various elements compared to its predecessors, such as the crossover design, driver selection and internal cavity shape. These changes are intended to reduce the Q factor of the resonance peak in the high frequencies while optimising the bass for an improved listening experience.
The Pure earphones offer very neutral sound reproduction with natural timbre, making them suitable for a wide range of applications, from monitoring to gaming, as well as simply listening music. Compared to the Hexa, the Pure headphones offer more powerful bass, more neutral midrange, and slightly brighter treble.
Truthear Pure : Frequency response curve
Like the brand's other multi-driver earphones, the Pure offers excellent phase consistency across the entire frequency range, ensuring no distortion due to phase divergence for a pleasant and detailed listening experience.
Truthear Pure: Silver-plated OFC cable
The Pure comes with a 3.5mm to CIEM 0.78mm 2-pin silver-plated OFC copper cable, guaranteeing high-quality signal transmission without external interference.
Truthear Pure : connected to their cable
Product typeIn-ear monitors (IEM)
Drivers1x Dynamic driver
3x Balanced armature drivers
Membrane du haut-parleur dynamiqueØ10mm liquid crystal polymer (LCP)
Impedance13.8Ω±15% @1kHz
Sensitivity124dB
Total harmonic distortion (THD)≤ 1% @ 1kHz (94dB)
Frequency response7Hz-40kHz
CableDetachable
Earphone connectors0.78mm 2 pins
Cable terminationJack 3.5mm
Cable materialsSilver-plated OFC copper
Package1x Truthear Pure
1x 3.5mm jack to 0.78mm 2-pin cable
1x Carrying bag
7x Pairs of ear tips
Impedance (Ω)13.8
Efficiency / Sensitivity (dB)124.0
WirelessNo
Phone call featureNo
Noise reductionNo
La claque !
Bon... mis à part des RHA (T10 ?) il y a fort longtemps, je suis assez novice dans le domaine des iems.
Mais par contre, histoire de pouvoir situer mon avis, j'ai une belle collection de casques planaires/dynamiques (Monolith M1070, Hifiman Ananda, Fidelio X2HR, Drop Hifiman HE-4xx, Drop Sennheiseir HD58x, Sony MDR-1A, Sony WH-1000XM4, ...), dont mon préféré actuellement est sans conteste le Monolith M1070.
Donc, concernant les Truthear Pure, j'ai passé pas mal de temps à lire/écouter des tests en tout genre et j'ai longtemps hésité entre les Truthear Pure, les Meze Alba et les 7Hz Timeless II.
Et bien, je ne suis pas déçu de mon choix !
Les Truthear Pure sont tout bonnement fantastiques et me feraient presque oublier tout le reste.
Je les ai testés sur divers amplis/dac/dap et il sont très à l'aise dans toutes les situations (Sabaj D5 + Topping A90, Xduoo XD-05, Fiio BTR17, Shanling M3X, ...).
Je ne vais pas épiloguer avec tout le vocabulaire audiophile habituel, mais il a tout ce qu'il faut où il faut niveau son.
Ils sont très agréable à porter. Et tout respire la qualité.
Le seul bémol (pour chipoter) c'est le pouch au lieu d'une petite boite solide pour les ranger, mais c'est vraiment histoire de trouver un moins ;-)
Donc en résumé, super content de cet achat ;-)
This review has been posted for TRUTHEAR PURE In-Ear Monitors IEM Dynamic Balanced Armature 13.8 Ohm 124dB 7Hz-40kHz
With the Pure, Truthear offers high-performance in-ear earphones, direct descendants of the Hexa. Like their predecessors, they are equipped with a...
