AUDIOPHONICS TDA-S50 Amplifier TDA7498E Class D 2x 70W 4 Ohm
4.8 / 5
Reference : 8681
49,90 €tax incl.
41,58 € tax excl.
Audiophonics TDA-S50
Class D TDA7498 Amplifier 2x50W 8Ω
amplificateur audiophonics class d tda7498
This amplifier with a 100% aluminum housing based on the TDA7498 digital amplifier provides comfortable output power when used at 36VDC (100W under 4 Ohm).
It can be supplied from a DC voltage of 15 to 36V DC or AC 12 to 24V AC..
Compact and easy to use, it is ideal for powering bookshelf speakers and will even make you feel comfortable with high-performance floorstanding speakers. With its volume knob and ON/OFF switch, the amplifier offers a very good comfort of use. The status LED on the switch illuminates when the unit is switched on.
Power supply example : Power supply adapter 100-240V to 24V 4A.
PDF of TDA7498E chip
Also available in DIY version TDA7498E amplifier module.
ChipTDA7498E
Supply voltage (power supply not included)VDC : 15-36V (recommanded : 18-30V)
Output power under 8Ω / 36V2 x 50W
Output power under 4Ω / 36V2 x 100W 1% THD / 2 x 70W 0.06% THD
Volume potentiometer-
InputRCA Stereo
OutpurSpeaker terminal (Banana and bare wire compatible)
Power supply voltageJack DC 5.5/2.1mm (power supply not included)
Case material100% aluminium
ColorNoir
Dimensions108 x 90 x 35mm
Poids378g
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTDA7498E
Power (W)80.0
18 reviews
Very Reliable
I have been using that small amplifier for more than ten years now. It sounds as good as the first day. It drives two bookshelf Focal 8 ohms enclosures (equipped with 13cm and 25mm tweeter), it is delivering powerful and accurate sound. I feed the amplifier with a 24V 4A DC power supply.
This review has been posted for AUDIOPHONICS TDA-S50 Amplifier TDA7498E Class D 2x 70W 4 Ohm
Exceptionnel pour le prix, même sous alimenté.
J'ai pris cet ampli, plutôt par curiosité, juste pour voir ce que c'était. Je voyais tous ces avis élogieux et je me disais « Pas possible, ils n'ont jamais entendu un bon ampli ! ».
J'ai connu la classe D lors de mes cours d'électronique orientation Radio TV début 1990 et à l'époque, à part les mégaphones et amplis de sono, ça n'avait pas beaucoup de succès. C'était un peu agressif ! Du coup, j'étais resté sur cette idée.
Comme point de comparaison, j'ai un vieux gros Japonais de ± 20Kg, mais aussi un NAD 3020 i dont je trouve que l'on en dit beaucoup trop sur son sujet.
Je ne m'attendais pas à trouver ça dans un boîtier si petit et surtout si bon marché. C'est une sonorité très propre, relativement détaillée. Une très belle précision, pas d'agressivité du tout, une belle image stéréophonique. La localisation des instruments est assez précise. Tout le spectre semble bien présent et sonne plus « monitoring » que Hifi. Bref, quelque chose de tout à fait inattendu.
En toute sincérité, le NAD 3020 ne tient pas la comparaison, quand on les compare, on entend vraiment le manque de netteté du NAD et sa faiblesse dans le bas du spectre. Oui, celui-ci (le TDA S50) est plus net, plus précis, tout en restant aussi doux.
La comparaison avec le gros Japonais est plus nuancée. Là, je ne sais pas dire qui fait mieux. Difficile comparaison. Le « classe D » se montre plus net, plus précis, mais moins ample et manque d'épaisseur et de relief. Mais il n'est aussi alimenté qu'en 20V au lieu de 36V. Je ne sais pas si 36V apporteraient un plus de ce côté-là.
Intrinsèquement ce petit ampli, compte tenu de son prix et de sa taille, est absolument exceptionnel (mais ils le sont probablement tous dans cette catégorie). Bref, ça m'a vraiment réconcilié avec la les amplis à découpage. De toute évidence, l'avenir de la Hifi est là.
Points forts :
Equilibre spectrale.
Détail et douceur.
Tiens bien en puissance malgré les 20V
Bonne dynamique.
Netteté des instruments.
Points faibles :
Manque un rien de relief et d'épaisseur, voire de rondeur.
Bref on est pas loin d'un ampli sans faute et pourtant c'est le bas de gamme.
Bon, tout ça sont sur des modestes Monitor Audio, j'imagine que sur du haut de gamme, ça ne passerait pas aussi bien. Mais pour le prix c'est hallucinant !
Oui, petit défaut : le gauche et le droit sont inversés. En revanche, pas le moindre bruit parasite.
Fais très bien le boulot dans les graves pour le prix.
4 étoiles car malgré le prix, le son me semble "peu joueur" face à mon push-pull d'EL34.
Bref, tout à fait satisfait.
Essayé et adopté
Jusqu'à présent je n'avais pas trouvé de remplaçant à mon Fx-Audio D802 dont les qualités audio me satisfont pleinement.
Ma config (pièce d'écoute environ 25m2):
Un Raspberry Pi sous Volumio ou MoodeAudio en source, un Topping D10, un D802 connecté en optique, en diffusion des Quad S-2 ou QAcoustics Concept 20 (actuellement les Quad S-2) et un caisson de basse Elipson PLANET SUB (dispose d'une entrée HP..).
Le Topping D10 a remplacé avec succès une carte digi+ qui était sur le Raspberry. J'ai essayé également d'autres FDA comme le Sabaj A3 ou le Fx-audio D502 mais qui ne m'ont pas fait changer (respectivement soit un manque de puissance, soit une légère baisse de rendu associée à un pop lors de la mise sous tension).
Je dispose d'un commutateur d'ampli DYNAVOX AMP-S. J'ai ainsi pu comparer ce petit ampli Audiophonics (en RCA sur le D10) avec le D802 (en optique sur le même DAC). Je n'ai constaté aucune différence à l'oreille entre les 2 amplis après les avoir réglés à 0.2db d'écart sur un bruit rose avec l'application Android "Sound Analyzer App". N'ayant pas de système de mesure autre qu'un smartphone (Sound Analyzer App et Spectroid), j'en resterai sur mes impressions d'écoute...
La raison principale du choix de cet ampli face au D802, c'est que cela m'évite de devoir chercher systématiquement la télécommande à chaque démarrage pour passer en mode direct (les connaisseurs comprendront..)
Autre point positif, cet ampli a une bonne réserve de puissance (même en 24V) et je n'en viendrais pas à bout. Je n'écoute pratiquement jamais au-dessus de 80db (à 2,5 m) et l'ampli peut monter bien au-delà sur mes enceintes.
Pour finir, aucun pop ON/OFF sur les HP avec l'utilisation d'un bloc prise avec interrupteur.
Bref que du bon...
Bravo Audiophonics !
Bon Ampli 2*50
Reçu aujourd'hui. fonctionne parfaitement. Convient parfaitement à mon besoin qui est d'amplifié la sortie casque d'une radio internet vers 2 HP dans plafond d'une chambre. Bon son et largement suffisant en puissance.
Trés content du produit . A voir dans le temps.
