Je l'utilise pour alimenter mes Transducteurs Clark Synthesis, il est parfaitement adapté. Fréquence de coupure réglable, strappé en Mono, il est parfait.
By buying this product you get 27 loyalty points
Warning, before connecting this amplifier you must select the power option matching your electrical network (220V or 110V).
Amplifier Class A/B - 1x150W 8 Ohm - 2x75W 4 Ohm
The Dayton Audio APA150 2x75W on 4 Ohm is the perfect integrated amplifier from in a small aluminum housing. Powerful and musical, it brings a real solution of great ease of use with a stereo input, a power button and a volume on the front. It thus brings for a soothed budget, the capacity to control speakers libraries and speakers columns of quality.
The Dayton Audio APA150 has an "old fashioned" design with discrete transistor components on its path with a toroidal transformer for realistic dynamics. Its refined design allows it to produce a particularly attractive and musical sound for an affordable budget of a disconcerting ease of use.
The Dayton Audio APA150 has an active filter adjustable from 50Hz to 150Hz allowing it to be transformed into an amplifier for subwoofer. The mono mode button allows 150w on one channel to drive a single bass speaker for example. The amp has a 15-minute auto sleep mode that can be disengaged.
" The Dayton Audio APA150 amplifier is a serious device that keeps its appearance and sound reproduction from being blurred, powerful and well-structured at the bottom of the spectrum, and benefits from a clever technical design. "
" The Dayton Audio APA 150 performs along the lines that we have sunk into in budget amplifiers. No doubt with good speakers and content, the APA 150 will provide an enjoyable experience. "
| Specifications | |
| Class | A/B |
| Stereo output power | 2x75W 4 Ohm |
| Mono output power | 1x150W 8 Ohm |
| Input | x1 RCA |
| Output | Speaker terminal |
| Input impedance | 47 KOhms |
| Power supply | 110V or 230V (Adjustable switch) |
| SNR | 100dB |
| Active adjustable filter | 50Hz - 150Hz |
| General | |
| Weight | 6kg |
| Dimensions | 170 x 174 x 392mm |
| Color | Black |
| Power cable | Inclued |
| Input | RCA |
| Output | RCA |
| Color | Black |
| Channel | 2 (Stereo) |
| Class | Class A / AB |
| Amplifier chip | LM324 |
| Power (W) | 150.0 |
| Remote Control | No |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Thierry P.
Gilles H.
