FX-AUDIO FX270 PRO AB Class + Tube Amplifier 6K4 Class A 48W 4 Ohm
FX-Audio FX270 PRO Tube Amplifier 6K4 Class A 33W 8 Ohm
This tube amplifier FX-Audio FX 270 Pro equipped with two tubes 6K4 offers a warm sound and a great accuracy in its restitution.
4.0 / 5
Reference : 12519
219,00 €tax incl.
182,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
FX-Audio FX270 Pro
Valve class D integrated Amplifier 33W 8Ω
FX-Audio FX270 Pro Amplificateur à tubes
The FX-Audio FX270 Pro is a AB Class amplifier with Class A tube preamp, capable of delivering 33W at 8Ω (48W 4Ω). Incorporating two 6K4 tubes, the FX270 offers a warm and detailed sound.
AOP TI NE5532
The amplifier is also equipped with two NE5532 operational amplifiers (AOPs) from TI mounted on DIP8. These provide low noise and distortion for high efficiency.
Insérer texte alternatif ici
The FX-Audio FX270 Pro also allows via two rotary knobs on the front of the device to adjust the bass and treble. A Tone ON / OFF button turns these settings on or off to switch to Direct Audio mode.
Connectivity side, it is simple and effective, with two stereo RCA inputs and HP terminal blocks to connect two speakers.
FX-Audio fx270 pro
Output power48W 4Ω
33W 8Ω
Inputs2x Stereo RCA
OutputSpeaker (R+L)
Impedance
SNR99dB
THD0.26%
Miscellaneous
ColorNoir
Case materilAluminium
Dimensions27 x 14 x 42cm
Weigth2kg
Accessories1x IEC Cable
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTube
Power (W)33.0
2 reviews
Bon petit ampli
Bon petit ampli minimaliste,son assez chaleureux grâce aux tubes.
Puissance un peut faible,sur mes enceintes Monitor Audio de faible rendement(85 db) s'essoufle assez vite si on met trop fort.
Dommage que l'alimentation soit "a découpage" et non linéaire avec un bon transfo torique.
Malgré tout c'est agréable à l'écoute,jamais agressif.
Prix très attractif.
This review has been posted for FX-AUDIO FX270 PRO AB Class + Tube Amplifier 6K4 Class A 48W 4 Ohm
Qualités et légers défauts
Appareil très bien construit; mais très chaud à l'usage. La capot devrait être ajouré ( au moins au dessus des tubes. )
Sur mon exemplaire les leds du contrôleur de tonalité ne fonctionne pas; le contrôleur lui fonctionne normalement.
Le son est REELLEMENT meilleur avec le remplacement des 2 NE5532 par des OPA2604 ( BB ) montés sur support.
