OCTAVIO AMP Class D Amplifier Streamer TPA3250 PCM1798 2x65W 4 Ohm 24bit 192kHz
Octavio unveils the AMP, a compact, high-performance amplifier with advanced network connectivity that allows you to enjoy your music wherever it is stored. The Octavio is a versatile device that will adapt to all situations and needs, while offering an accurate and musical sound reproduction.
Reference : 15969
699,00 €tax incl.
582,50 € tax excl.
Octavio AMP
Octavio AMP Amplificateur Class D Lecteur Réseau TPA3250 PCM1798 2x65W 4 Ohm 24bit 192kHz
An efficient amplification stage
The Octavio AMP's amplifier stage uses a TPA3250 chip, which allows it to develop a comfortable power of 2x65W under 4Ω or 2x35W under 8Ω, with a high efficiency of over 92%.
Versatile connectivity
In addition to advanced wireless connectivity, the AMP also provides full connectivity for easy integration into your existing audio system. There is 2x auxiliary input on stereo RCA, an optical Toslink input, a USB-A port and an RJ45 Ethernet connector. On the output side, the device offers speaker terminals that accept banana plugs, but also a subwoofer output for a high-performance connected 2.1 system.
Your music in streaming
Octavio offers with its connected devices an ergonomic, design and practical control application. It allows you to access all your music directly from your smartphone, whether it is stored locally, on a NAS or in the memory of your smartphone. It also allows you to access many supported streaming services or a wide choice of web radios.
Octavio AMP : Supported streaming services
AirPlay 2, Spotify Connect & Tidal Connect
The Octavio AMP also supports AirPlay 2, Spotify Connect and Tidal Connect wireless streaming protocols. The former will allow you to stream your music from a Mac, iPad or iPhone, while the latter will allow you to stream and control your music directly from the Spotify and Tidal apps.
Octavio Sound Filter
The Octavio AMP embeds the brand's Sound Filter technology. This technology analyzes the audio signal at the input and compares it to the output signal. This process eliminates any potential noise or disturbance, in order to provide a clear and detailed sound.
Your music throughout the house
With Octavio, you can set up a real multiroom audio system in your home. Thus, it becomes possible to broadcast your music in each room and control the playback individually or by group directly from the mobile application.
As compact as it is powerful
Compact, the Octavio AMP measures only 20cm in length and depth, for a height of 4cm. It will thus easily find a place in your HiFi or TV cabinet, to integrate with your audio system.
Made in France
Octavio performs the vast majority of the design steps in their workshop, in France. Thus, the assembly of the products, the software development and even the after-sales service are done in France.
Product typeAmplifier
Streamer
Inputs1x Ethernet RJ45
2x Stereo RCA
1x Optical Toslink
1x USB-B
OutputsSpeaker terminals
1x Subwoofer output
ConnectivityWiFi 802.11 b/g/n 2.4GHz / GHz
Bluetooth 5.0 A2DP
Amplification chipTPA3250
Output power2x65W @ 4Ω (24V)
2x35W @ 8Ω (24V)
2x100W @ 4Ω (32V)
2x60W @ 8Ω (32V)
Efficiency> 92%
DAC ChipBurr Brown PCM1798
Supported sampling ratesPCM up to 24bit 192kHz
THD< 0.005% @ 1W
CPUAllwiner R328
ARM Cortex TM-A7 dual-core 1.2GHz
WiFi/Bluetooth chipAMPAK AP6256
Linkplay Next Gen Modules
Supprted file formatsFLAC, OFF, ALAC, WMA, APE, MP3
Dimensions20 x 20 x 4cm
Package1x Octavio AMP
1x Power cable
1x Power supply 24V
InputWiFi
InputPhono
InputRJ45
OutputSubwoofer
OutputSpeaker terminal
DAC / ADC ChipBurr Brown PCM1798
Max sampling rate192kHz
Channel2 (Stereo)
Amplifier chipTPA3250
Power (W)65.0
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsDeezer
Octavio unveils the AMP, a compact, high-performance amplifier with advanced network connectivity that allows you to enjoy your music wherever it...
