SMSL SA-36A Plus Digital Amplifier TPA3118 Bluetooth 4.1 2x 50W / 4 Ohm Silver
Reference : 12585
59,90 €tax incl.
49,92 € tax excl.
The SMSL SA-36A Plus silver front panel is a remarkably efficient, compact audio amplifier with a wide range of connectors that allows it to be used with many different sources.
This amplifier has a USB input, SD card input, 3.5mm AUX jack input, and a Bluetooth 4.1 wireless antenna.
Its amplifier module TPA3118 Class D allows it to deliver an output power of 2x30W at 8 Ohm. The choice of the electronic components assigned to it is not overlooked.
You can't miss its front panel with 5 buttons. A Play / Pause button, the 2 volume buttons +/-, the Power button, as well as the button for the different EQ Mode settings.
Qobuzissime for the SMSL SA-36A Plus
(Review by Qobuz)
" This S.M.S.S.L SA-36A Plus switching amplifier may have amazed us even more than the AD18 and A8 models of the brand by offering, at a lower power level but not negligible, and at a really low price, sound performances that remind us furiously of those of its big brothers. "
Test Qobuz
General specifications:
  • Amplifier chip: TPA3118 / Class D
  • Output power: 2x 30W @ 8 Ohm / 2x 50W @ 4 Ohm
  • Bluetooth version: 4.1
  • Maximum Sampling Rate: 16 Bit / 44kHz
  • EQ Mode: Flat / Rock / Pop / Classical / Jazz
  • Power supply 24V DC
  • Power consumption: 22W
  • Power consumption at rest: 0.5W
  • Accepts file formats: WMA / MP3
Connection system / Dimensions / Weight: :
  • USB-A Input (Up to 64GB) / SD Card Input (Up to 32GB)
  • Output: Stereo speaker terminals
  • AUX Jack 3.5mm Jack Input
  • Dimensions: 250x188x68mm
  • Weight: 322g
  • Colour: black
  • Facade: Silver
  • Supplied with: 24V AC adapter / Bluetooth antenna
InputJack 3.5mm
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Amplifier chipTPA3118
Power (W)30.0
3 reviews
Le Mode EQ
Le mode EQ m'a vraiment laissé septique. Il n'y a aucune explication sur le mode d'emploi imprimé sur l'emballage. J'ai appuyé plusieurs fois sur le bouton. Je n'ai pas noté de changement particulier dans le son. Je me demande si ce mode est vraiment opérant. Bref à oublier. D'autant qu'avec une utilisation sur un ordinateur, on peut modifier le son directement dans son lecteur audio (Vox par exemple).
This review has been posted for SMSL SA-36A Plus Digital Amplifier TPA3118 Bluetooth 4.1 2x 50W / 4 Ohm Silver
Top!
Bonjour,
J'ai acheté ce petit ampli pour une utilisation desktop avec un ordinateur. La qualité du son est superbe et la puissance bien suffisante (pour ce type de configuration).
Deux choses à noter:
_ L'ampli, l'ordinateur et tous le reste sont branchés sur une multi prise. Dès que j'allume la multi prise, l'ampli s'allume automatiquement. Je dois donc penser à l'éteindre à chaque fois si je ne veux pas l'utiliser.
_ Étant sur Mac, les touches du clavier pour augmenter ou baisser le son fonctionnent parfaitement avec cet ampli! C'est très pratique, surtout que les toutes petites touches de l'ampli ne sont pas très pratique.
En conclusion: très beau design en alu, toute petite taille, très bon son très détaillé (sans être trop analytique). Je recommande!
Small but efficient
Parfait pour convertir un vieux meuble radio des années 60 à la musique dématérialisée et au streaming.
Une notice d'utilisation serait la bien venue avec quelques explications sur les réglages EQ MODE.
