SMSL SA-36A Pro Digital Amplifier TDA7492PE Class D 2x 25W / 4 Ohm
4.8 / 5
Reference : 9718
49,90 €tax incl.
41,58 € tax excl.
SMSL SA-36A Pro
Digital Amplifier TDA7492PE Class D 2x 20W / 8 Ohm
SMSL SA-36A Pro Amplificateur numérique TDA7492PE Class D 2x 20W / 8 Ohm
The SMSL SA-36A Pro is a remarkably efficient compact amplifier that has benefited from many developments since its launch on the market. It now includes a TDA7492PE D2DAP Class D amplifier module delivering 2x 25W at 4 Ohms and 2x 20W at 8 Ohms. There is also a lot of choice in the choice of components assigned to it. The materials and finishes are all assets that make the SA-36A Pro a particularly efficient amplifier suitable for a wide range of audio systems.
Product typeDigital amplifier
Amplification chipTI TDA7492PE
Max power2x20W @ 8 Ohm
2x25W @ 4 Ohm
Frequency response20Hz - 22kHz @ +/-3dB
SNR102dB
Dynamic range103dB
THD+N0.1% @ 1kHz
ProtectionShort-circuit
Input1x Stereo RCA
OutputSpeaker terminal (banana plug compatible)
Volume controlYes
Power supply12V DC (included)
MaterialCNC machined Anodized Aluminium
Dimensions150 x 92 x 43mm
Weight600g
Package1x SMSL SA-36A Pro
1x Power supply
Channel2 (Stereo)
Amplifier chipTDA7492PE
Power (W)20.0
4 reviews
Mr.
Received in very quick time in Ireland and everything was perfect. You get full marks from me.
Tom
This review has been posted for SMSL SA-36A Pro Digital Amplifier TDA7492PE Class D 2x 25W / 4 Ohm
Bien, mais encore améliorable
J'avais déjà un petit ampli classe D "Fiio A1" très satisfaisant (simple et agréable à l'écoute) pour driver une paire de 10 cm fostex large-bande. En comparaison, ce petit ampli SMSL est encore moins encombrant, mais il est si léger que lorsqu'on appuie sur le switch d'alimentation, il glisse en arrière...à moins de mettre la main dessus en actionnant l'inter avec le pouce. Je préférais le potentiomètre interrupteur du Fiio, plus fonctionnel et plus simple encore. Par ailleurs, les 2 led bleues qui indiquent la mise sous tension de l'appareil sont cachées sous le bouton de volume, les rendant invisibles, même dans l'obscurité. Peut-être faudrait-il percer le bouton au niveau du repère afin de laisser passer un peu de lumière?
Pour ce qui est du son, c'est neutre, un poil brillant peut-être ou manquant de grave c'est propre, et pour le prix très abordable on peut dire qu'on ne peut qu'en être satisfait lorsqu’il s'agit de constituer une base pour un petit système d’appoint compact.
Exactement ce qu'il me fallait !
Avant tout, super service client qui m'a donné rapidement toutes les infos dont j'avais besoin pour savoir si je pouvais utiliser cet ampli dans mon véhicule aménagé, donc branché sur une batterie 12V avec panneau solaire.
La plage de fonctionnement (12 à 15V) est donc idéale pour une utilisation dans un véhicule (aménagé ou non, ça peut aller à l'avant).
Le connecteur d'alimentation est standard, donc on peut en bricoler un autre pour le brancher à la batterie, sans détruire celui d'origine pour le 220V.
Ampli compact, super finition, puissance bien suffisante pour moi, et son très propre.
Après quelques utilisations prolongées, j'ai l'impression qu'il consomme très peu, et aucun problème de puissance avec une alimentation sur batterie 12V.
Livraison rapide, on commande serein, et tout se passe bien !
Très impressionnant !
J'ai d'abord acheté cet ampli dans la perspective d'avoir un ampli très basse consommation qu'il est possible d'alimenter directement avec une batterie 12V (maison de vacances, solaire autonome et ghetto blaster DIY :)). Je savais que les amplis de Classe D sont très performants dans leur utilisation de l'énergie mais là je suis littéralement tombé sur le c**. À un volume plus que suffisant pour sonoriser une petite pièce l'ampli consomme près d'un watt au transfo et encore moins branché directement en courant continu (mes enceintes sont à haut rendement mais quand même!). J'ai refait les mesures plusieurs fois tant je n'arrivais pas à le croire! Mes autres ampli consomment 30 à 40 fois plus à un volume sonore comparable. La taille de l'ampli est aussi très surprenante, pas plus long qu'un étui à lunettes, un peu plus large. Et enfin le son est très propre, très détaillé, il n'y a pas de parti du spectre particulièrement en retrait. Sur certaines musiques je dirais même que je préfère cet ampli à mes ampli hi-fi. Dans certains cas par contre et c'est peut-être subjectif, je trouve le son plus léger, moins appuyé, comme si la puissance plus faible était perceptible et venait à manquer. Le son reste très propre quand on monte le volume et le niveau maximum est très satisfaisant pour tous les usages, même embêter les voisins. D'une manière générale je suis extrêmement satisfait de cet achat, le rapport qualité prix est exemplaire et je pense tester bientôt un plus gros modèle avec DAC.
