Max sampling rate
DAC / ADC Chip
Amplifier chip
Class
Power (W)
2 - 1000
Channel
Input
Output
Remote Control
Streaming services
Color
Jerome L.
Rémi D.
N'hésitez pas
Antony C.
Best rapport Qualité/Prix !
Integrated amplifiers
Here you'll find our selection of high-fidelity integrated amplifiers. Unlike power amplifiers, these have a pre-amplification section, notably via a volume knob and/or a source selector. Whether Mono or Stereo, you can plug your HiFi speakers directly into them and enjoy their impeccable sound.
  • Ref : 15391
    In Stock
    This affordable Class D amplifier is based on a TOPA3251D2 amplifier chip, ensuring a power of 2x140W under 4Ω and this with high efficiency. It will therefore have no trouble accompanying most speaker models. Moreover, it takes advantage of the PurePath Ultra HD technology, allows to maintain a very low level of distortion on the whole frequency...
    64,90 € 54,08 €Ex.
    In Stock
  • Ref : 17701
    In Stock
    The SVS Prime wireless pro SoundBase is a robust 300w stereo amplifier (150 watt per channel) with a 192 KHz/24-bit DAC housed in a compact and high-tech box. It is able to drive any loudspeaker to its full potential with plenty of dynamics, powerful bass and crystal clear sound. Its internal components are of audiophile quality. This integrated audio...
    799,00 € 665,83 €Ex.
    In Stock
  • Ref : 19962
    In Stock
    Thinkya unveils a singular device with its DVR-102, a Class AB integrated amplifier based on the use of ECC83/ECC82 tubes for its preamplification stage and Toshiba PNP A1941 and NPN C5198 transistors for its power stage. One of its key features is that it features RCA input and output jumpers, enabling it to be used as a preamplifier or only as a...
    479,00 € 399,17 €Ex.
    In Stock
  • Ref : 19127
    In Stock
    Tinyside introduces one of their first ready-to-use devices. The TSA3610 is a Class D based on a TPA3116D2 amplifier chip, amplifier with 2x50W output power at 4 Ohm, featuring a CSR8635 Bluetooth 4.1 chip. This amplifier can be powered by any 12V-24V DC supply, and can be used to drive a 4Ω or 8Ω passive speaker while taking...
    54,90 € 45,75 €Ex.
    In Stock
  • Ref : 20214
    With the AD-3PRO+, Tonewinner offers a Class A integrated stereo amplifier rated at 2x165W at 8Ω, and relying on Toshiba 1941/5198 transistors and OPA 1656 to deliver warm, precise sound reproduction. Its numerous analog and digital inputs enable this device to fit into any possible configuration. Its integrated ES9038 DAC chip enables the AD-3PRO+...
    2 390,00 € 1 991,67 €Ex.
    In Stock
  • Ref : 19419
    In Stock
    The Tonewinner AD-60 is an integrated power amplifier offering 2 x 80W power at 4Ω while maintaining very low distortion and response time thanks to its Class AB design. Furthermore, its wide range of connectors means it can easily be used in a wide range of configurations, from home cinema with its HDMI/ARC socket to remote use via a simple...
    449,00 € 374,17 €Ex.
    In Stock
  • Ref : 19416
    In Stock
    549,00 € 457,50 €Ex.
    In Stock
  • Ref : 18762
    In Stock
    The Tonewinner AD-66D PRO is an efficient and versatile Class A amplifier with a proven technical foundation for musical and detailed sound. Its circuitry uses audiophile-grade components to ensure excellent performance, including low noise and distortion. It also provides a complete set of connectors to meet the vast majority of needs for home audio...
    659,00 € 549,17 €Ex.
    In Stock
  • Ref : 20216
    In Stock
    With the AD-86D, Tonewinner offers a Class A integrated stereo amplifier rated at 2x120W into 8Ω, and relying on TTC-5200/TTA1943 transistors and 1678 OPA to deliver sound reproduction that's both precise and warm. Its extensive connectivity means this amplifier can be integrated into many different configurations, even benefiting from Bluetooth...
    1 090,00 € 908,33 €Ex.
    In Stock
  • Ref : 18655
    In Stock
    ToneWinner unveils an all-in-one device with its AD89D Class AB integrated amplifier. This 2.1-channel amplifier features a CD player, high-fidelity Bluetooth reception and an HDMI ARC port. Powerful and versatile, the Tonewinner AD-89D is capable of delivering up to 2x 130W at 8 ohm.
    In Stock
  • Ref : 17347
    In Stock
    As imposing in appearance as it is in power, the Tonewinner AD-99D is a powerful, versatile and robust Class AB stereo integrated amplifier. It delivers a pure and delicate sound, with a beautiful dynamic and richness of sound. It uses two balanced modules equipped with Toshiba transistors. It is completed by an efficient and reliable power supply stage...
    1 390,00 € 1 158,33 €Ex.
    In Stock
  • Ref : 17500
    In Stock
    Topping now offers the excellent LA90 in a version using discrete circuits, the LA90 Discrete. The result is a powerful amplifier with incredible metering for a breathtaking listening experience. The new NFCA discrete amplifier circuitry ensures extremely clear and precise sound reproduction. The amplifier has the same features as the first LA90, with...
    899,00 € 749,17 €Ex.
    In Stock
  • Ref : 17503
    In Stock
    In Stock
  • Ref : 15658
    Topping offers with its PA3s a small balanced Class D amplifier, simple, powerful and affordable. It is based on two Infineon MA12070 amplifier chips and has two balanced and single-ended outputs.
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 15659
    In Stock
    In Stock
  • Ref : 18001
    In Stock
    Topping's PA5 II amplifier is a compact and powerful model, adopting a totally balanced structure and an innovative Class D amplifier circuit, enabling it to develop a significant power of 2x100W under 4Ω with a low level of distortion. The excellent parameterisation carried out by the brand's engineers ensures clear, clean and deep sound...
    199,00 € 165,83 €Ex.
    In Stock
  • Ref : 18003
    In Stock
    In Stock
  • Ref : 17642
    The Topping PA7 is a powerful amplifier, based on a Class D architecture and benefiting from an intelligent and particularly careful design. It is thus capable of developing a significant power while maintaining a very low level of distortion. The technologies used ensure a clear, precise and deep sound reproduction. In addition, the balanced structure of...
    349,00 € 290,83 €Ex.
    In Stock
  • Ref : 17644
    In Stock
    In Stock
  • Ref : 19340
    In Stock
    An evolution of the WiiM Amp connected amplifier, the WiiM Amp Pro retains the features and functions of its predecessor, but with a few notable improvements. The WiiM Amp Pro, a high-performance connected amplifier, now features an ES9038Q2M DAC chip supporting sampling rates up to PCM 32bit 384kHz. In addition, the Class D amplification circuit using a...
    459,00 € 382,50 €Ex.
    In Stock
  • Ref : 18387
    In Stock
    The WiiM Amp is an amplifier and streamer that's as compact as it is versatile and high-performance! It lets you distribute your music extremely simply via DLNA, AirPlay 2, Bluetooth (bidirectional) or Chromecast. So you can easily access your music library, whether it's stored on a computer, NAS or smartphone. What's more, control of the device and...
    369,00 € 307,50 €Ex.
    In Stock
  • Ref : 18424
    In Stock
    In Stock
  • Ref : 20685
    In Stock
    The WiiM Vibelink Amp, marks the brand's first foray into non-connected integrated amplifiers, designed to pair with WiiM Mini, WiiM Pro, WiiM Pro+ and WiiM Ultra streamers. This audiophile amplifier integrates an ES9039Q2M DAC chip, a TI TPA3255 amplifier chip and six OPA1612 OPAs, all within a PFFB (Post-Filter Feedback) structure.
    In Stock
  • Ref : 20686
    In Stock
  • Ref : 11845
    In Stock
    Wondom proposes here a TA2024 Clas D amplifier delivering a power of 2x15W under 4Ω, ideal for any secondary or auxiliary HiFi installation. Thanks to its compact design, its elegant case and its great ease of use, this amplifier will allow you to listen to your favorite songs on your audio systems with extreme simplicity.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 16546
    In Stock
    The xDuoo DA-100, although compact and affordable, is very versatile, taking on the functions of Class D amplifier, headphone amplifier and DAC. Its careful design embeds a TPA3116 amplifier allowing it to develop a 2x50W power, a MAX97220 headphone amplifier and a ES9018K2M DAC ensuring low distortion and high SNR. A 1.3" OLED screen displays information...
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 16835
    In Stock
    The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its amplifier stage is indeed based on a TI TPA3116 chip, allowing to deliver a 2x30W power output under 4Ω with a high efficiency. However, the circuit also integrates a 12AU7 tube, allowing to enjoy the soft and...
    129,00 € 107,50 €Ex.
    In Stock
