AMP25.2 Class AB Integrated Amplifier 2x30W 4 Ohm Bluetooth 5.0 AptX HDMI ARC Black
The AMP25.2 integrated amplifier is an affordable, high-performance Class AB amplifier that will integrate easily into a Hi-Fi installation thanks to its sober, elegant and compact design. Its amplification power is 2x30w into 4Ω, so it's capable of driving a large number of speakers.
Reference : 18041
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 27-06-2025.
AMP25.2  Integrated Amplifier
Class AB 2x30W 4 Ohm Bluetooth 5.0 AptX Noir
AMP25.2 Amplificateur Intégré Class AB 2x30W 4 Ohm Bluetooth 5.0 Noir
The AMP25.2 integrated amplifier is an affordable, high-performance Class AB amplifier that will integrate easily into a Hi-Fi installation thanks to its sober, elegant and compact design. Its amplification power is 2x30w into 4Ω, so it's capable of driving a large number of speakers. Its amplification stage is based on a symmetrical circuit. Its connectors are made of gold-plated pure copper, which significantly improves signal transmission and prevents corrosion and oxidation.
In addition, the AMP25.2's wide range of input connectors makes it quite versatile. An MV Silicon BP1048V2 chip enables it to accept U discs (WAV, FLAC, APE, MP3), Bluetooth reception and an HDMI ARC signal. Its design limits interference and noise in the audio signal output. Overall, the sound delivered is precise and transparent, with a wide soundstage and high dynamics.
5.0 Bluetooth transmission
A Bluetooth receiver chip supports the SBC / MP3 and aptX (A2DP) transmission codecs.
Solid, elegant and compact casing
The AMP25.2 housing is made of solid anodized aluminum. Its strong angles and recessed volume knob give the AMP25.2 a stylish, elegant appearance. Moreover, this chassis provides heat dissipation in keeping with the AMP25.2's power.
AAMP25.2 Amplificateur Intégré Class AB 2x30W 4 Ohm Bluetooth 5.0 Noir
A remote control
The AMP25.2 is equipped with a remote control for selecting input source and volume level, as well as applying basic functions such as play/pause, previous, next, mute and power-on/off.
Versatile, efficient connectivity
The AMP25.2's connectivity features a stereo RCA input and speaker terminals, as well as a 6.35mm jack output for headphone listening. A "plug & play" USB-A port is also present, for connecting a source device such as a computer without having to install a driver. An HDMI ARC port lets you enjoy a Hi-Fi TV experience, and two SPDIF inputs are also integrated on the rear panel: coaxial and optical Toslink. Finally, a Bluetooth antenna makes it possible to receive a source signal remotely.
The headphone output and speaker terminals are active simultaneously, and both are affected by volume control.
1Source indicator
2Volume control
36.35mm jack output
4Right channel speaker terminal
5Bluetooth antenna connector
6RCA stereo input
7HDMI ARC input
8USB-A input
9Optical toslink input
10Coaxiale SPDIF input
11Switch on/off
12DC12V power supply
13Left channel speaker terminal
Product typeIntegrated amplifier
ClassAB
ChannelsStereo (2)
Inputs1x RCA stereo
1x USB-A
1x HDMI ARC
1x Coaxial SPDIF
1x Optical Toslink
Bluetooth
OutputsSpeaker terminals
1x 6.35mm jack
Output power2x 30W / 4Ω @ 15V, 1kHz, THD+N 10%)
Distorsion0.008%
Frequency response6Hz-80kHz (-3dB)
Supported audio formatsUSB-A port: WAV, FLAC, APE, MP3
Supported sample ratesToslink and coaxial : 24bits 48kHz
Power supplyDC 12V
Dimensions150 x 150 x 50mm
Weight1.2Kg
Package1x AMP25.2 integrated amplifier
1x 12V power adapter (EU power cable not included, available as accessory)
1x Bluetooth antenna
InputHDMI ARC
OutputJack 6.35mm
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)30.0
The AMP25.2 integrated amplifier is an affordable, high-performance Class AB amplifier that will integrate...
