The AMP35 integrated amplifier is an affordable, high-performance Class AB amplifier that will integrate easily into a Hi-Fi installation thanks to its sober, elegant and compact design. Its amplification power is 2x30w into 4Ω, so it's capable of driving a large number of speakers. Its amplification stage is based on MOSFET transistors, two discrete single-ended AOPs and a fully symmetrical circuit. Its isolated power supply and design limit interference and noise at the output of the audio signal. Overall, the sound delivered is precise and transparent, with a wide soundstage and high dynamics.
The AMP35 incorporates a Qualcomm QCC5125 Bluetooth receiver chip to support high-quality transmission codecs such as LDAC and aptX HD, as well as adaptive aptX.
The AMP35's case is made of solid anodized aluminum. Its strong angles and built-in volume knob give the AMP35 a stylish, elegant appearance. In addition, the casing provides heat dissipation to match the AMP35's power.
The AMP35's connectivity features a stereo RCA input and speaker terminals, as well as a 3.5mm jack for headphone listening. A "plug & play" USB-A port is also present, for connecting a source device such as a computer without having to install a driver. A Bluetooth antenna also enables remote reception of a source signal.
Both the headphone output and speaker terminals are active simultaneously, and both are affected by volume control.
1 | Right channel speaker terminal |
2 | RCA input |
3 | 3.5mm jack output |
4 | Bluetooth antenna connector |
5 | USB-A input |
6 | Switch ON/OFF |
7 | DC 12V-15V power supply input |
8 | Left channel speaker terminal |
Product type | Integrated amplifier |
Class | AB |
Channels | Stereo (2) |
Inputs | 1x RCA stereo 1x USB-A port Bluetooth |
Ouputs | Speaker terminals 1x 3.5mm jack |
Output power | 2x 30W / 4Ω @ 15V, 1kHz, THD+N 10%) |
Distorsion | 0.008% |
Frequency response | 6Hz-80kHz (-3dB) |
SNR | 110dB |
Power supply | DC 12V-15V |
Color | Black |
Dimensions | 150 x 150 x 50mm |
Weight | 1.5Kg |
Package | 1x AMP35 integrated amplifier 1x 12V power adapter (EU power cable not included, available as accessory) 1x Bluetooth antenna |
Input | RCA |
Input | USB |
Input | Bluetooth |
Output | Speaker terminal |
Output | Jack 3.5mm |
Color | Black |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | Transistors |
Power (W) | 30.0 |
Remote Control | No |
