AUDIOPHONICS DAW-S250NC Class D Integrated Amplifier NCore NC252MP DAC ES9038Q2M WiFi Bluetooth 2x250W 4 Ohm 32bit 768kHz DSD
Versatile and powerful, we offer you with the DAW-S250NC an integrated amplifier with digital inputs to which you can simply add speakers to enjoy your music in the best possible way. Combining comfortable power, a powerful DAC, complete WiFi and Bluetooth connectivity and precise volume control, this amplifier is a must-have for anyone who wants to equip themselves with a quality sound system without having to worry about a multitude of devices dedicated to specific functions.
By buying this product you get 79 loyalty points
Reference : 17004
790,00 €tax incl.
658,33 € tax excl.
Audiophonics Workshop amplifiers range
Audiophonics DAW-S250NC
Class D Integrated Amplifier NCore NC252MP DAC ES9038Q2M WiFi Bluetooth 5.0 2x250W 4 Ohm 32bit 768kHz DS256
Audiophonics DA-S250NC Amplificateur Intégré Class D NCore DAC ES9038Q2M Bluetooth 5.0 2x250W 4 Ohm 32bit 768kHz DSD512
Versatile and powerful, we offer you with the DAW-S250NC an integrated amplifier with digital inputs to which you can simply add speakers to enjoy your music in the best possible way. Combining comfortable power, a powerful DAC, complete connectivity and precise volume control, this amplifier is a must-have for anyone who wants to equip themselves with a quality sound system without having to worry about a multitude of devices dedicated to specific functions. The DAW-S250NC also opens the doors to music streaming thanks to its WiFi LinkPlay connectivity, allowing you to access your music from your network and your favorite applications.
Audiophonics DAW-S250NC Amplificateur Intégré Class D NCore DAC ES9038Q2M WiFi Bluetooth 5.0 2x250W 4 Ohm 32bit 768kHz DSD512
Incredibly effective amplification
The real engine of this DAW-S250NC, the Hypex NCore NC252MP Class D amplifier module delivers considerable power, up to 2x250W under 4Ω, with great efficiency and ease, while maintaining a compact size. Its main characteristic reveals itself in its great linearity and its ability to ensure a very low level of distortion. The DAW-S250NC reveals a sound reproduction as transparent as detailed to present you your music as close as possible to its recording in studio.
The NCore NC252MP also features its own SMPS power supply, consisting of a regulated half-bridge converter with synchronous rectification on the main output rails. This design is ideally suited for integration with a Class D amplifier, providing the amplifier with a stable, clean electrical signal and capable of responding quickly to more sudden power requirements.
Enjoy your music in every detail
The DAW-S250NC's digital-to-analog conversion is handled by a widely proven and audiophile-approved DAC, the ES9038Q2M from ESS Technology. This chip uses the patented HyperStream® II 32bit architecture and Time Domain Jitter Eliminator technology to deliver excellent performance. The result is incredibly accurate sound reproduction that captures every detail of your music.
This DAC also opens the door to very high resolution, supporting PCM audio streams up to 32bit 768kHz and DSD up to DSD256.
A complete connectivity to adapt to all your needs
The DAW-S250NC offers a complete range of connections to easily integrate into your audio system and adapt to your use. Its rear panel features digital inputs, coaxial, optical Toslink and USB-B (XMOS). For the outputs, you can of course count on high quality speaker terminals, but also on a Pre-Out output via RCA.
This RCA output offers you several possibilities:
- connect an active subwoofer
- connect another integrated amplifier
Wireless without limits
Take control of your DAW-S250NC remotely in a perfectly intuitive way with its WiFi connectivity. Featuring a WiFi module based on proven LinkPlay technology, the DAW-S250NC lets you stream your music over your network, whether from your smartphone, computer, NAS, or any other connected device. The module is compatible with DLNA/UPnP, AirPlay and Spotify Connect protocols.
Also enjoy access to your favorite streaming applications and web radios through a dedicated control application, allowing you to remotely control your device through an ergonomic interface.
In addition, it also becomes possible to integrate multiple DAW-S250NC amplifiers into a multi-room system, all of which can be controlled synchronously or independently via the app. This means you can equip different rooms in your home while keeping control of the system in a completely transparent way.
Moreover, the WiFi module is bit-perfect, allowing playback as close as possible to the original signal, even for high-resolution audio streams up to 24bit 192kHz.
A single application to control your system
The WiiM Home application, available for free on Android and iOS, allows you to remotely control your DAW-S250NC via WiFi. Thanks to its ergonomic and intuitive interface, simply stream your music from your smartphone and connect to your home network. You'll also have access to numerous audio streaming platforms, such as Spotify, Deezer, Tidal, Qobuz, Amazon Music and even TuneIn and iHeartRadio web radios.
Want to set up a multi-room system to enjoy your music throughout your home? WiiM Home also allows you to control each device connected to it, either synchronously or independently, all in a single application.
Broadcast from your sofa
In addition to its physical connectivity, the DAW-S250NC provides high quality Bluetooth 5.0 reception capability, which is extremely convenient and will allow you to stream and control your music wirelessly quickly and easily, directly from your smartphone or tablet for example.
A sober and modern design
The components are perfectly protected by a robust aluminum case. Optimal heat dissipation is provided by a series of openings on the cover and rear panel, allowing for good airflow. The front panel of the DAW-S250NC features a beautiful black acrylic front panel, a modern and elegant aesthetic touch. Behind this panel is a beautiful OLED screen, which displays the volume level, the active input or the type of signal received by the device. It will also allow you to navigate through the menus and access all the options of the DAW-250NC.
DAW-S250NC test by ON-MAG
"A small, connected Class D hi-fi amplifier that's all about digital technology and shaking things up."
Product typeIntegrated amplifier
InputsBluetooth 5.0
WiFi
1x USB-B
1x Coaxial
1x Optical Toslink
OutputsSpeaker terminals
1x Stereo RCA Pre-Out
AmplifierHypex NCore NC252MP
DACESS ES9038Q2M
USB InterfaceXMOS XU208
Output power2x 250W @ 4Ω
2x 150W @ 8Ω
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD DoP up to DSD256
Coaxial / Optical : PCM up to 24bit 192kHz, DSD DoP up to DSD64
THD+N0.0015%
SNR121dB
OLED ScreenBrightness not adjustable, but switches off after 40 seconds
Supported WiFi protocolsDLNA / UPnP
AirPlay
Spotify Connect
Supported streaming services (via WiiM Home app)Spotify
Deezer
Tidal
Qobuz
Amazon Music
Napster
Pandora
QQMusic
Supported webradios (via WiiM Home app)TuneIn
iHeartRadio
RadioParadise
vTuner
Power supply110-230V AC
ColorGray
Total dimensions (WxDxH)300*291*60mm
Weight~ 2.45kg
Package1x Audiophonics DAW-S250NC
1x Remote control (batteries included)
1x Power cable
1x Bluetooth / WiFi antenna
FFT measure - 5W - 4 Ohm
FFT DA-S250NC - 5W - 4 Ohm
FFT measure - 4.4V Rms No load
FFT DA-S250NC - 5W - No load
InputWiFi
OutputSpeaker terminal
ColorGray
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)250.0
Remote ControlYes
4 reviews
Bluffant
Ampli surprenant, puissance impressionnante, son équilibré, très détaillé. Présence des voix très réaliste, basses quasi sans limites.
Alimente des enceintes "maison" basses de 38 cm et médium aigus large bande de 21 cm, sans faiblir. Rapport qualité prix excellent.
This review has been posted for AUDIOPHONICS DAW-S250NC Class D Integrated Amplifier NCore NC252MP DAC ES9038Q2M WiFi Bluetooth 2x250W 4 Ohm 32bit 768kHz DSD
Quelle efficacité !
Un ampli très compact pour la puissance qu’il délivre. Quel plaisir d’avoir un amplificateur en classe D.
Les entrées sont forcements numériques.
Un ampli de qualité qui rivalise et dépasse, en termes de qualité sonore, avec des amplis 2,5 fois plus chers (CAMBRIDGE EVO 150 par exemple).
L’ampli n’est pas spécialement beau, mais sobre et très efficace. Utilisé avec des Focal ARIA 936.
Audiophonics a su écouter les utilisateurs, le firmware a été mis à jour et la façade a été changée. Il n’y a donc plus de problème de « clac » (firmware) ni de son très aigu provenant de la façade lorsqu’elle était allumée (remplacement de la façade gratuitement que j’ai pu faire moi-même sans renvoyer l’ampli).
Un produit qui est simple, efficace et fonctionnel.
Pour les bricoleurs il est possible de prendre la version DA-S250NC (sans wifi) et d’y accoler un Raspberry Pi.
Je recommande ce produit et le service d’Audiophonics. C’est vraiment très agréable d’avoir un service support qui fait confiance à ses clients.
Un rapport Q/P remarquable
Après m'être séparé d'un système à éléments séparés (dac + ampli intégré + récepteur bt + chromecast audio) j'étais à la recherche d'un ampli tout-en-un plus simple à piloter et moins énergivore.
Le DAW-S250NC associé à une paire de Focal Aria 906 + caisson Velodyne SPL 800u délivre un son transparent et équilibré qui convient parfaitement à mes oreilles.
La mise en service est hyper facile à réaliser, tout fonctionne parfaitement. Les petits soucis de jeunesse du firmware ont disparu.
Cependant, j'aurai mis 6 étoiles avec une sortie casque, une entrée RCA et une télécommande à chiffres permettant de lancer directement des flux radio mis en favoris dans l'App WiiM.
Bravo !
Good Integrated Amp
I find this to be a good amplifier and I greatly appreciate its power, clarity, and versatility. I have no reservations about it and I am pleased to have it in my system.
My only regret is that it does not have RCA inputs. I would like to connect a phono amp directly into it, but that is my problem, not this amplifier's. This is a modern integrated amp that accepts Bluetooth and WiFi streaming, and phono is for dinosaurs--like me. With a DAC built in and COAX, OPT and USB inputs, this really is a versatile and advanced amplifier. It is very responsive to the remote control and the design is aesthetic: simple and pleasing. It is remarkably light for the rated power output and VERY convenient to use. I connected audio from a video projector via Bluetooth and was impressed by the quality of sound and the excellence of the connection. I was streaming videos and films with audiophile sound and quick and easy connection.
I have been able to stream from my computer, my laptop, my phones, and the phones of guests with quick and easy connections that provided stable wireless connection and audiophile-quality sound. I have also been able to connect a Topping electrostatic headphone amp that I also purchased through Audiophonics to it, and the sound is clean and clear.
I am happy with this purchase and will no doubt recommend this amplifier to friends.
I recently moved to France and wanted to buy French-built products for my new home and new life and I am very proud that this amplifier, which is advanced and of good quality is French. French-designed and French-built and in line with legendary French quality.
 (5)
Versatile and powerful, we offer you with the DAW-S250NC an integrated amplifier with digital inputs to which you can simply add speakers to enjoy...
