AUDIOPHONICS HPA-INT450ET Integrated Amplifier
Audiophonics is proud to present the HPA-INT450ET. This Class D integrated amplifier relies on a pair of Purifi 1ET6525SA amplifier modules coupled with a Hypex SMPS1200A400 power supply to deliver incredible performance. Like all Audiophonics Workshop products, this HPA-INT450ET is meticulously designed and hand-assembled in our workshop in France.
3.0 / 5
By buying this product you get 179 loyalty points
Reference : 20478
1 790,00 €tax incl.
1 491,67 € tax excl.
Audiophonics Workshop amplifier range
Audiophonics HPA-INT450ET Integrated Amplifier Stereo Class D Purifi 1ET6525SA 2x450W 4 Ohm
Audiophonics HPAI-SA6525ET : Front view
The Audiophonics HPA-INT450ET is a powerful, robust and high-performance amplification solution. It is capable of powering demanding HiFi audio systems, while revealing sound reproduction of incomparable finesse, rich in detail and perfectly transparent. There's no compromise here between power and sound accuracy. The on-board Purifi modules feature a particularly rigorous design, delivering exceptional measured performance.
All elements and components are integrated into a solid, sturdy aluminum housing with a sleek, modern design. This chassis also features openings and heat sinks on the sides to dissipate heat efficiently. What's more, its design effectively limits the impact of interference on the audio signal.
Audiophonics HPA-INT450ET: Purifi amplification modules
Each channel of the Audiophonics HPA-INT450ET amplifier circuit is equipped with its own Purifi 1ET6525SA amplifier module. These use high-performance Class D architecture, with available power of 2x450W into 4Ω or 2x230W into 8Ω (at 1% THD) and high efficiency of over 94%. They also guarantee a very low level of THD, intermodulation distortion and noise, for a rich, precise and perfectly transparent sound reproduction, perfectly respecting the original audio signal to reproduce your music with unequalled fidelity and without coloration. It also guarantees a wide, realistic sound image, for perfect immersion.
Purifi's ongoing research into non-linear control theory has led to the development of the first mathematically accurate large-signal model for self-oscillating amplifier controllers. This breakthrough enables the feedback circuit to be fully optimized, resulting in a significant performance improvement over other designs. Furthermore, these Purifi 1ET6525SA modules feature a complete protection system for enhanced durability.
Audiophonics HPAI-SA6525ET : Purifi module
Audiophonics HPAI-SA6525ET : Hypex power supply
Audiophonics HPA-INT450ET: Hypex SMPS1200A400 power supply unit
The power supply stage of the Audiophonics HPA-INT450ET uses an ultra-high-efficiency Hypex SMPS1200A400 switch-mode power supply module, capable of developing 1200W of power. This has been specifically designed and developed by Hypex to provide the voltage required for optimal operation of the amplifier modules.
This high-quality, low-noise power supply perfectly meets the energy requirements of the Purifi 1ET6525SA amplifier modules. Furthermore, the amplifier modules themselves have an excellent ability to reject power supply noise. As a result, the HPA-INT450ET is highly insensitive to power grid imperfections and voltage/current variations that can cause parasitic noise.
Audiophonics HPA-INT450ET: Using the Line4 bypass input
Line input 4 (AMP-IN) bypasses the preamplifier stage completely. When active, no compensation or attenuation is applied to the audio signal before it is sent to the amplifier. This means that the source used with line input 4 must have its own volume control. This input has been designed for use as a power amplifier. It allows you to control the volume from an external preamplifier (such as an AV receiver). So, for example, you can use the HPA-INT450ET as part of a home theater and HiFi setup.
Never use Line4 input without first connecting it to a source with volume control. Otherwise, the fully amplified signal could damage your speakers.
Audiophonics HPAI-SA6525ET : Volume bypass line input
Audiophonics HPA-INT450ET: Proprietary buffer interface board
The two amplifier modules are driven in phase opposition to cancel the Power Supply Pumping effect. This allows for greater power supply stability, alternately distributing current calls on each rail and thus increasing its capacity. A voltage regulation stage is used to optimize the power supply to the OPAs and the auxiliary voltage supplied to the modules. One Audiophonics OPA1656 OPA is used per channel. These are very low-distortion OPAs, offering the highest transparency with very low THD. They are mounted on a socket so they can be replaced if necessary.
In addition, a gain control is located on the underside of the unit to suit all applications. Four gain settings are available: 12.5dB, 20dB (default), 25dB and 29dB.
Audiophonics HPAI-SA6525ET : Volume control chip
Audiophonics HPA-INT450ET: MUSES72320 volume controller
The Audiophonics HPA-INT450ET's integrated volume control features a high-quality MUSES72320 chip. This stereo electronic volume controller offers excellent performance with very low noise and distortion levels, thanks in particular to its resistor ladder circuit.
Audiophonics HPA-INT450ET: A sober, modern design
Housed in a robust aluminum case, components are perfectly protected. Optimum heat dissipation is ensured by a series of apertures on the cover and rear panel, allowing air to circulate freely. The front of the HPA-INT450ET features a magnificent black acrylic panel, a modern and elegant aesthetic touch. Behind this panel is a beautiful display, showing volume level, active input and type of signal received by the device. It also lets you navigate menus and access all HPA-INT450ET options.
HPA-INT450ET Overview
Audiophonics HPAI-SA6525ET : schéma
1ON/OFF button
2Source selector button
3Screen
4Volume knob
5Right channel speaker output
6Left channel speaker output
7Pre-out RCA output
8Balanced XLR input
9Single-ended RCA inputs
10RCA bypass input
11Trigger input
12Trigger output
13Power connector
THD vs Frequency @ 4Ω
Audiophonics HPAI-SA6525ET : Courbe THD vs Fréquence
THD+N vs Power @ 1kHz
Audiophonics HPAI-SA6525ET : Courbe THD+N vs Puissance
Frequency response @ 2.83V
Audiophonics HPAI-SA6525ET : Courbe réponse en fréquence
Product typePower amplifier
Amplification modules2x Purifi 1ET6525SA
Amplification typeClass D
Number of channelsStereo (2)
Output power2x230W @ 8Ω, 1% THD
2x450W @ 4Ω, 1% THD
2x510W @ 2Ω, 1% THD
Efficiency> 94%
Inputs1x Balanced stereo XLR
3x Single-ended stereo RCA
1x Bypass stereo RCA
OutputSpeaker terminals
Trigger5-12V in/out on mono Jack 3.5mm
THD+N0.00035% @ 1W, 1kHz
0.0001% @ 10W, 1kHz
0.00005% @ 100W, 1kHz
0.00035% @ 1W, 20Hz-20kHz
0.00029% @ 10W, 20Hz-20kHz
0.0001% @ 100W, 20Hz-20kHz
IMD (CCIF)0.0000003% @ 1W, 18.5kHz+19.5kHz
0.0000006% @ 10W, 18.5kHz+19.5kHz
0.0000005% @ 100W, 18.5kHz+19.5kHz
IMD (DIM)0.002% @ 1W, DIM30
0.002% @ 10W, DIM30
0.009% @ 100W, DIM30
Idle noise (ICN)6.6µV @ A-wt
Dynamic range137dB @ A-wt
SNR137dB @ A-wt
Frequency response±0.01dB @ 8Ω, 20Hz-20kHz
±0.01dB @ 4Ω, 20Hz-20kHz
±0.01dB @ 2Ω, 20Hz-20kHz
Input impedanceRCA : 10kΩ
XLR : 20kΩ
Output impedance0.03mΩ @ 1kHz, 1A
< 0.35mΩ @ 20Hz-20kHz, 1A
XLR Gain / Input sensitivity for max power @ 1% THD12.5dB / 10.06Vrms
20dB / 4.24Vrms
25dB / 2.39Vrms
29dB / 1.51Vrms
RCA Gain / Input sensitivity for max power @ 1% THD12.5dB / 5.03Vrms
20dB / 2.12Vrms
25dB / 1.24Vrms
29dB / 0.75Vrms
ScreenNon-adjustable brightness, but switches off after 50 seconds
Supply voltage100-240V AC (switchable, selection switch under the device)
Housing materialAluminum
Total dimensions328 x 435 x 73mm
Weight5.8kg
Package1x Audiophonics HPA-INT450ET
1x Remote control
1x Power cord
InputXLR
Channel2 (Stereo)
Amplifier chip1ET6525SA
Power (W)450.0
Remote ControlYes
Überraschend gut
Das war meine erste Erfahrung mit purifi. Der Verstärker ist wirklich gut, und kann leicht mit meiner A/B Endstufe mithalten. Leider ist der pre nicht von der gleichen Qualität. Auch war keine Bedienungsanleitung beigelgt. Deswegen habe ich das Gerät zurückgeschickt.
This review has been posted for AUDIOPHONICS HPA-INT450ET Integrated Amplifier Stereo Class D Purifi 1ET6525SA 2x450W 4 Ohm
Audiophonics is proud to present the HPA-INT450ET. This Class D integrated amplifier relies on a pair of Purifi 1ET6525SA amplifier modules coupled...
