D325E Amplifier Stereo Class D
The D325E is a Class D integrated amplifier designed for stereo amplification, based on the TPA3255 chip architecture. It delivers up to 230W into 4Ω, utilizing high-efficiency conversion to ensure stable performance while minimizing heat loss, resulting in controlled operation even under sustained load. Input is via stereo RCA connectors, and output is via speaker terminals.
Reference : 21707
54,90 €tax incl.
45,75 € tax excl.
D325E Class D Stereo Amplifier TPA3255 2x230W 4 Ohm
D325E : Front view
The D325E is a Class D integrated amplifier designed for stereo amplification, based on the TPA3255 chip architecture. It delivers up to 230W into a 4Ω load, utilizing high-efficiency power conversion to ensure stable performance while minimizing heat loss, resulting in reliable operation even under sustained load. Input is via stereo RCA connectors, and output is via speaker terminals.
Technical Specifications
Product typeIntegrated amplifier
Amplifier typeClass D
Input1x Stereo RCA
OutputSpeaker binding posts
Impedance4-8Ω
Amplification chipTPA3255
Power2x230W @ 4Ω, 48V, 1% THD+N
2x165W @ 6Ω, 48V, 1% THD+N
2x130W @ 8Ω, 48V, 1% THD+N
Total harmonic distortion (THD)< 0.02%
Signal-to-noise ratio (SNR)110dB
Power supply24-48V DC via Jack DC 5.5/2.5mm (sold separately)
Dimensions126 x 166 x 40mm
Weight600g
Package1x D325E Amplifier
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)230.0
D325E Amplifier Stereo Class D TPA3255 2x230W 4 Ohm
The D325E is a Class D integrated amplifier designed for stereo amplification, based on the TPA3255 chip architecture. It delivers up to 230W into...
