Low Frequency Amplifier with EQ for Subwoofer and Exciter
Dayton Audio's DTA-100LF is a Class D low frequency amplifier specifically designed to drive a subwoofer or vibrator. Powerful, it is able to develop a maximum power of 100W under 4Ω or 70W under 8Ω. It also includes three crossovers and a variable phase control to protect, integrate and tune your speakers in any system.
An adjustable subsonic crossover is used to protect the speakers from over-excursion. A low-pass filter allows the speakers to be integrated with full-range speakers. Finally, a single-band parametric crossover helps manage peaks that may arise from the room acoustics themselves.
The Dayton Audio DTA-100LF is also capable of detecting an input signal to automatically turn on and off. It also comes in a convenient compact case with brackets for mounting under a shelf or desk, for example.
To use the power cable on European/French power outlets, an adapter sold separately is required.
Product type | Low frequency amplifier |
Input | 1x Stereo RCA |
Outputs | 1x Stereo RCA Speaker terminals |
Max output power | 100W @ 4Ω 70W @ 8Ω |
THD | < 1% |
Frequency response | 20Hz - 180Hz ±3dB |
SNR | 95dB |
Input sensitivity | 200mV |
Low pass crossover range | 30Hz - 200Hz |
Phase adjustment | 0° - 180° variable |
Line input impedance | 22kΩ |
Line output impedance | 4kΩ |
Supply voltage | 120-240VAC |
Consumption | Max : 150W Standby : 1.8W |
Dimensions | 190.5 x 139.7 x 50.8mm |
Weight | 1.5kg |
Input | RCA |
Output | Speaker terminal |
Output | RCA |
Color | Black |
Channel | 2 (Stereo) |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 100.0 |
Remote Control | No |
