DAYTON AUDIO WB40A Multiroom WiFi Bluetooth Amplifier 2x40W 4 Ohm
The Dayton Audio WB40A is a compact amplifier capable of delivering 2x40W of power under 4Ω, integrating Bluetooth and WiFi connectivity and therefore particularly convenient for transforming any speaker system into a wireless audio streaming system controlled via an application. The WB40A is therefore compatible with the Dayton Audio Hi-fly application, which allows you to control playback, sources or even the multiroom.
Reference : 13997
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 29-05-2026.
Grantie 5 ans
Dayton Audio WB40A
Dayton Audio WB40A Amplificateur Bluetooth WiFi Multiroom 2x20W 8Ω
The Dayton Audio WB40A is a compact amplifier capable of delivering 2x20W power at 8Ω, integrating Bluetooth and WiFi connectivity and therefore particularly handy for transforming any set of speakers into a wireless audio streaming system controlled via an app. The WB40A is compatible with the Dayton Audio Hi-fly or Linkplay Legacy Player applications, which allow you to control playback, sources and multiroom.
Multiroom
xxx
Multiroom
Multiroom WiFi Bluetooth Amplifier 2x20W 8 OhmWith the WB40A's multiroom function, you can start playing your music directly in multiple rooms of your home for uninterrupted listening.
xxx
Multi Channels
It is also possible to play your favorite songs on multiple devices independently or create groups of devices.
xxx
Multi Users
Multiple users can share the broadcast in the house, each with the ability to control the audio source for different devices
Take control of your music
The Hi-Fly WiFi multiroom playback technology and associated application allows you to stream your music directly from your favorite online streaming services, listen to files stored on your device, play music stored on your computer / NAS (local network) or files stored on a USB stick / hard disk connected to the WB40A. The Dayton Audio WB40A and all other Dayton Audio Hi-Fly compatible products can work together using the Hi-Fly or Legacy Player application.
xxx
Compact & Flexible
The WB40A's small size and high versatility allows it to be easily integrated into many HiFi systems
xxx
User friendly
The WB40A is controlled in an extremely simple and intuitive way, directly from the dedicated mobile application or via the supplied IR remote control.
xxx
Convenience
No need to buy a separate device for WiFi streaming and a separate amplifier, the WB40A does both!
Fast and easy setup
Thanks to Dayton Audio's Hi-Fly or Linkplay Legacy Player mobile application, the WB40A is very easy to configure. Simply download the application from the Play Store for Android devices or the App Store for iOS devices. Once installed, the application guides you through a short series of simple steps to implement the receiver.
Application Legacy Player Store Android
Application Hi-Fly App Store iOS
Full fingertip control
The Hi-Fly application turns your smartphone or tablet into a remote control to control all your connected Dayton Audio devices that are compatible with the application. You can start your music from a streaming application like Spotify or from your local network or enjoy the files stored on your phone. Hi-Fly allows you to play your music to your various connected devices independently or create groups for a complete multiroom experience. In addition, your music continues to play even if your smartphone turns off or you receive a call. If you do not want to use your smartphone to control playback and broadcasting, an IR remote control is also provided.
Bluetooth
The Dayton Audio WB40A also includes Bluetooth connectivity to stream your music. Any device connected via Bluetooth (transmission) can stream audio to the WB40A, without the need to use the Hi-Fly application. Particularly useful for quickly changing source devices.
Product typeAmplifier
PowerRMS : 2x20W @ 8Ω
Max : 2x40W @ 8Ω
Inputs1x Stereo Jack 3.5mm
1x Ethernet RJ45
1x USB-A 2.0
WiFi
Bluetooth
OutputsSpeaker terminals
Supported WiFi protocolsDLNA, AirPlay
WiFi Standard801.11 b/g/n
Frequency response20Hz - 22kHz
SNR< 94.5dB
THD0.005%
Crosstalk< 94.1dB
Supported audio formatsMP3, WMA, AAC (AAC+), Apple Lossless, FLAC, APE, WAV
Supported web radio file formatsMP3, WMA, AAC
Supported playlist typesiTunes, Windows Media Player, WinAMP, Rhapsody
OS CompatibilityMac OS, iOS, Android, Windows
Supply voltage15VDC 2.4A on Jack DC 5.5/2.5mm (Power supply sold separately)
Dimensions (WxDxH)114.3 x 114.3 x 25.4mm
Weight885g
Package1x Dayton Audio WB40A
1x Stereo RCA to Jack 3.5mm cable
1x Jack 3.5mm to Jack 3.5mm cable
1x Remote control
InputWiFi
InputJack 3.5mm
InputRJ45
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipN/A
Power (W)20.0
Remote ControlYes
The Dayton Audio WB40A is a compact amplifier capable of delivering 2x40W of power under 4Ω, integrating Bluetooth and WiFi connectivity and...
