DOUK AUDIO G100 Subwoofer Amplifier
The Douk Audio G100 is a subwoofer amplifier relying on Class D amplification via a TPA3116D2 chip paired with a pre-processing stage based on four NE5532 op-amps to stabilise the signal and ensure controlled bass response. It delivers up to 2x50W into 4Ω in BTL mode, while its PBTL configuration concentrates current capacity to reach 100W into 2Ω, enabling efficient drive of dedicated low-frequency drivers while maintaining stability under demanding loads.
Reference : 22154
72,90 €tax incl.
60,75 € tax excl.
Shipping date: 01-12-2026.
Douk Audio G100 Subwoofer / Bass Shaker Amplifier Class D TPA3116D2 2x50W 50Hz-300Hz
Douk Audio G100 : Front view
Intended for car audio simulation setups or home theatre systems, it integrates an adjustable low-pass filter spanning 50Hz to 300Hz, allowing precise tuning of the subwoofer's frequency range to suit the application, while the RCA input and Bluetooth 5.3 connectivity facilitate integration with a variety of sources.
Product typeSubwoofer amplifier
InputsStereo RCA
Bluetooth 5.3
OutputSpeaker terminals
Amplification chipTPA3116D2
Amplification typeClass D
Output powerBTL: 2x50W @ 4Ω
PBTL: 100W @ 2Ω
Total harmonic distortion plus noise (THD+N)0.19%
Signal-to-noise ratio (SNR)≥ 101dB
Compatible speaker impedanceBTL: 4-8Ω
PBTL: 2-8Ω
Low-pass filter range50Hz-300Hz
Low-pass filter slope24dB/octave
Input sensitivityRCA: 0.22V
Supported Bluetooth codecSBC
Power supply voltage15-24V DC
Dimensions124 × 114 × 33mm
Weight507g
Package1x Douk Audio G100
1x 24V power adapter
1x Bluetooth antenna
Channel2 (Stereo)
Channel1 (Mono)
Amplifier chipTPA3116D2
Power (W)50.0
Power (W)100.0
DOUK AUDIO G100 Subwoofer / Bass Shaker Amplifier Class D TPA3116D2 2x50W 50Hz-300Hz
The Douk Audio G100 is a subwoofer amplifier relying on Class D amplification via a TPA3116D2 chip paired with a pre-processing stage based on four...
