DOUK AUDIO G7 Integrated Amplifier PFFB Audio Selector Switch
The Douk Audio G7 is a high-power Class D integrated amplifier combining HiFi amplification, audio selector, and speaker switch functionality in a compact and modern format. Based on an architecture using two TPA3255 amplification chips, it can operate in both stereo 2.0 mode and 4.0 channel mode, delivering up to 2x300W at 4Ω or 4x150W at 4Ω + 4Ω depending on the selected configuration.
By buying this product you get 34 loyalty points
Reference : 21938
349,00 €tax incl.
290,83 € tax excl.
Douk Audio G7 PFFB Integrated Amplifier Audio Selector Switch 2xTPA3255 2x300W/4x150W 4 Ohms
Photo of the DOUK AUDIO G7
The Douk Audio G7 is a high-power Class D integrated amplifier combining HiFi amplification, audio selector, and speaker switch functionality in a compact and modern format. Based on an architecture using two TPA3255 amplification chips, it can operate in both stereo 2.0 mode and 4.0 channel mode, delivering up to 2x300W at 4Ω or 4x150W at 4Ω + 4Ω depending on the selected configuration. It integrates an internal 48V / 10A GaN power supply, three OPA1612 operational amplifiers, as well as an NJW1194 volume and tone controller, ensuring powerful, detailed, and controlled sound reproduction with extremely low distortion of only 0.002% and a signal-to-noise ratio greater than 112dB.
The G7 also benefits from PFFB (Post Filter Feedback) technology, allowing it to eliminate the load dependency typical of traditional Class D amplifiers and improve stability as well as sound quality with different speakers. Compatible with speakers from 4Ω to 8Ω, it features two groups of RCA inputs as well as a balanced TRS + XLR combo input, ensuring excellent compatibility with DACs, streamers, and professional audio sources.
On the output side, the G7 offers two groups of speaker terminals, usable either switchably or simultaneously to perform A/B tests, power two listening zones, or create a 4-channel configuration. It also integrates bass/treble tone adjustment over a ±10dB range, a bypass mode completely disabling the tone and volume circuits for pure power amplifier operation, as well as an instant mute function. The package is completed by large retro-style blue backlit analog VU meters with AGC, a 12V trigger input, a full-featured remote control, and a robust aluminum chassis. Powered by AC 100-240V, the G7 measures 275 x 190 x 78 mm and weighs 3.34kg, offering a powerful and versatile solution for both home HiFi and desktop setups.
Douk Audio G7: Dual TPA3255 Amplification, PFFB Technology and 2.0 / 4.0 Channel Modes
The G7 is based on two TPA3255 amplification chips renowned for their excellent audio performance, high energy efficiency, and ability to deliver high power with extremely low distortion. This architecture is combined with PFFB (Post Filter Feedback) technology, reducing dependency on speaker impedance variations in order to achieve a more stable response, improved linearity, and more natural sound reproduction regardless of the speaker model used.
The G7 can operate in both stereo 2.0 mode and 4.0 channel mode depending on the user’s needs.
Its two groups of speaker outputs notably allow:
  • powering two pairs of speakers
  • performing A/B comparisons
  • creating a multiroom or dual-zone setup
  • simultaneously using multiple speakers within the same system
This versatility makes it a particularly flexible solution for HiFi enthusiasts.
DOUK AUDIO G7: Dual TPA3255 Amplification, PFFB Technology and 2.0 / 4.0 Channel Modes
Douk Audio G7: Tone Adjustment and Bypass Mode
The G7 integrates bass and treble adjustment over a ±10dB range to easily adapt the sound reproduction according to the speakers or room acoustics.
The bypass mode completely bypasses the tone and volume circuits in order to obtain the purest and most transparent signal possible for critical audiophile listening.
DOUK AUDIO G7: Tone Adjustment and Bypass Mode
Overview of the Douk Audio G7
1Gain Indicator
2Source Indicator
3Output Indicator
4IR Receiver
5Bass Adjustment / Input Selector
6Treble Adjustment / Output Selector
7Standby / Volume Adjustment / Mute
8100-240V AC Power Input
9Speaker Output #A
10Speaker Output #B
112x RCA Input / 1x TRS/XLR Input
12Bypass/Tone Mode Switch
1312V Trigger IN
Technical Characteristics
Product TypePFFB Integrated Amplifier / Audio Selector Switch
Amplification Chip2x TPA3255
OPAmp3x OPA1612
Input2x RCA
1x Balanced TRS/XLR Combo
Output2x Speaker Terminals
Operating Mode2 channels / 4 channels
Output Power2x 300W @ 4 ohms
4x 150W @ 4 ohms + 4 ohms
Frequency Response20Hz-20kHz (±0.5dB)
THD+N0.002%
SNR≥112dB
Input SensitivityRCA: 2V
TRS+XLR: 4V
Recommended Impedance4-8Ω
Bass/Treble Tone Adjustment±10dB
Integrated Power Supply48V/10A DC
Power Supply100-240V AC Mains Power
Dimensions275x190x78mm
Weight3.34kg
Package Contents1x G7 Amplifier
Remote Control
Power Cable
InputXLR
InputJack 6.35mm
OutputSpeaker terminal
Channel2 (Stereo)
Channel4
Amplifier chipTPA3255
Power (W)150.0
Power (W)300.0
Remote ControlYes
DOUK AUDIO G7 Integrated Amplifier PFFB Audio Selector Switch 2xTPA3255 2x300W / 4x150W 4 Ohms
The Douk Audio G7 is a high-power Class D integrated amplifier combining HiFi amplification, audio selector, and speaker switch functionality in a...
