WONDOM GAU1 Class D Amplifier 2.1 with PC Interface for Arcade Cabinet / Simulator
The WONDOM GAU1 (AA-AS43111) is a 2.1-channel amplifier specifically designed for arcade cabinets, racing simulators, gaming machines, and multimedia applications requiring a powerful, compact, and easy-to-integrate audio solution. Based on a Texas Instruments TPA3116 amplifier combined with an integrated audio DSP, it delivers up to 2x50W into 4Ω for the stereo channels and 1x100W into 2Ω for the subwoofer channel, all powered from a 24V DC supply.
Reference : 22270
33,90 €tax incl.
28,25 € tax excl.
WONDOM GAU1 2.1 Amplifier with PC Interface for Arcade Cabinets / Racing Simulators TPA3116 2x50W + 1x100W 4/2 Ohm
WONDOM GAU1
The WONDOM GAU1 (AA-AS43111) is a 2.1-channel amplifier specifically designed for arcade cabinets, racing simulators, gaming machines, and multimedia applications requiring a powerful, compact, and easy-to-integrate audio solution. Based on a Texas Instruments TPA3116 amplifier combined with an integrated audio DSP, it delivers up to 2x50W into 4Ω for the stereo channels and 1x100W into 2Ω for the subwoofer channel, all powered from a 24V DC supply. The GAU1 supports Bluetooth and analog line inputs, while its front-panel USB-C port allows advanced real-time configuration from a PC. Users can adjust equalization, Bass Boost, crossover frequency, delays, and other DSP parameters directly through the dedicated software interface. External controls also allow volume, balance, bass level, crossover, power, and Bluetooth disconnect management without the need for a computer. Its sandblasted aluminum enclosure ensures excellent heat dissipation, while its locking Mini-Fit and Micro-Fit connectors guarantee quick and secure installation. The GAU1 also integrates extensive protections against overvoltage, undervoltage, overheating, short circuits, and DC offset detection, as well as a dedicated grounding terminal designed to eliminate ground-loop noise for clear, interference-free sound reproduction.
WONDOM GAU1
WONDOM GAU1: Powerful 2.1 Amplification for Arcade Cabinets and Simulators
Designed to deliver an immersive audio experience, the GAU1 combines two 50W stereo channels into 4Ω with a 100W bass channel into 2Ω. This 2.1 architecture accurately reproduces sound effects, music, dialogue, and low frequencies in arcade cabinets, racing simulators, and entertainment systems. Explosions, impacts, environmental effects, and soundtracks all benefit from dynamic and detailed playback.
WONDOM GAU1: Integrated DSP with Real-Time PC Control
Thanks to its integrated DSP processor, the GAU1 allows advanced audio processing adjustment via its USB-C port. The dedicated software interface enables real-time control of numerous parameters such as equalization, Bass Boost, crossover settings, delays, and output levels. Configurations can be saved and reloaded, making it easy to replicate the same sound profile across multiple machines.
WONDOM GAU1: Simplified Installation and Reliable Operation
The GAU1 features a compact 110 x 100 x 25mm format with cooling fins and mounting points for easy integration into confined spaces. Its locking Mini-Fit and Micro-Fit connectors prevent wiring mistakes and provide excellent vibration resistance. The aluminum enclosure also acts as a heatsink, while integrated protections against overvoltage, undervoltage, overheating, short circuits, and DC offset ensure safe and long-lasting operation. Finally, the dedicated ground terminal effectively eliminates ground-loop noise to preserve audio quality.
WONDOM GAU1 Overview
1Mini-Fit 2x1 Subwoofer Output
2Micro-Fit 2x1 Stereo L/R Output
312-24V Mini-Fit 2x2 Power Input
4External Control Port (JST PH 2x6 Pin)
5Grounding Ring Terminal Mounting Point
6C-Bracket Screw Terminals
7PC User Interface Programming Port (USB Type-C)
83.5mm Line Output
93.5mm Line Input
Technical Specifications
Product TypeAmplifier
ClassClass D
Number of Channels2.1
Amplifier ChipTPA3116
DSP
Input1x 3.5mm Line Input
Bluetooth
Outputs1x Stereo L/R Micro-Fit 2x1 Output
1x Mini-Fit 2x1 Subwoofer Output
1x 3.5mm Output
Output Power2x50W + 1x100W @ 4/2 Ohm
GainL/R: 27.7dB
Sub: 32.3dB
SNRL/R: 111.7dB
Sub: 102.4dB
THD+NL/R: 0.18%
Sub: 0.007%
Noise LevelL/R: 33.95uVrms
Sub: 152.6uVrms
Input Sensitivity775mVrms
Minimum Load ImpedanceL/R: 4 Ohm
Sub: 2 Ohm
Power Supply12-24V DC
Idle Current Consumption (24V DC, No Signal)0.118A / 0.128A / 0.156A
Idle Power Consumption (24V DC, No Signal)3.7W
Dimensions100 x 110mm
Weight280.8g ±10g
Package Contents1x AA-AS43111 GAU1 2.1 Gaming Amplifier
1x MiniFit 2X1CKT Cable for Subwoofer Output, 50cm / 19.69"
1x MicroFit 1X2CKT Cable for Right Channel Output, 50cm / 19.69"
1x MicroFit 2X1CKT Cable for Left Channel Output, 50cm / 19.69"
1x MiniFit 2X2CKT Power Cable, 50cm / 19.69"
1x Aluminum Cable Mounting Bracket
InputJack 3.5mm
OutputJack 3.5mm
OutputMicro-fit
OutputMini-fit
Max sampling rateNC
Channel2.1
Amplifier chipTPA3116D2
Power (W)100.0
Power (W)50.0
WONDOM GAU1 Amplifier 2.1 with PC Interface for Arcade Cabinet / Simulator TPA3216 2x50W + 1x100W 4/2 ohm
The WONDOM GAU1 (AA-AS43111) is a 2.1-channel amplifier specifically designed for arcade cabinets, racing simulators, gaming machines, and...
