DOUK AUDIO ST-01-PLUS Phono Amplifier
The Douk Audio ST-01-Plus is a powerful and versatile phono amplifier. It's based on a TPA3255 amplifier chip for output power of up to 2x 120W under 4 ohm with the supplied 48V 5A power supply. It also features Bluetooth 5.2 functionality, with support for high-definition SBC, aptX, aptX-LL, aptX-HD codecs thanks to a QCC304X chip.
Reference : 20731
154,00 €tax incl.
128,33 € tax excl.
Shipping date: 02-07-2025.
Douk Audio ST-01-Plus Phono Amplifier TPA3255 Bluetooth 5.2 aptX HD 2x 120W @ 4 ohm
Photo du DOUK AUDIO ST-01-PLUS
The Douk Audio ST-01-Plus is a powerful and versatile phono amplifier. It's based on a TPA3255 amplifier chip for output power of up to 2x 120W under 4 ohm with the supplied 48V 5A power supply. It also features Bluetooth 5.2 functionality, with support for high-definition SBC, aptX, aptX-LL, aptX-HD codecs thanks to a QCC304X chip. Numerous additional features, such as a vumeter and treble and bass tone control, make this an amplifier of choice. As for its interface, it features an RCA input, an RCA phono input, a speaker output and an AUX output on a 3.5mm jack, enabling you to set up a 2.1-channel system.
The AUX 3.5mm jack output and the speaker terminal output are controlled synchronously by the main volume and bass/treble.
Douk Audio ST-01-PLUS: A powerful amplifier
The Douk Audio ST-01-PLUS is equipped with a TPA3255 amplifier chip, enabling it to deliver substantial power output. In fact, it delivers up to 2x120W of power under a 4 ohm load with the supplied 48V 5A power supply. However, you can power it with a 48V 10A supply to enjoy an extended power level of up to 250W under 4 ohm.
Photo de la puce TPA3255 du DOUK AUDIO ST-01-PLUS
Douk Audio ST-01-PLUS power chart
Power supplyOutput power
32V/5A2x 78W @ 4 ohm
2x 71W @ 6 ohm
2x 65W @ 8 ohm
36V/6A2x 107W @ 4 ohm
2x 100W @ 6 ohm
2x 94W @ 8 ohm
48V/5A2x 120W @ 4 ohm
2x 110W @ 6 ohm
2x 102W @ 8 ohm
48V/10A2x 250W @ 4 ohm
2x 210W @ 6 ohm
2x 185W @ 8 ohm
La puce Bluetooth du DOUK AUDIO ST-01-PLUS
Douk Audio ST-01-PLUS: Bluetooth 5.2
The Douk Audio ST-01-PLUS features Bluetooth functionality thanks to a Qualcomm QCC304X chip. It supports codecs such as SBC, AAC, aptX, aptX-LL, aptX-HD for reliable, stable wireless transmission.
Douk Audio ST-01-PLUS: MM phono compatibility
This amplifier features a phono input, making it easy to enjoy your vinyl collection. It is compatible with MM cells.
Additional features of the Douk Audio ST-01-PLUS
Vumètre
Vumeter
A vumeter on the front panel adds a vintage touch and a neat aesthetic.
Contrôle des tonalités
Tone control
Two potentiometers let you adjust the sound for an experience as close as possible to what the user wants.
Douk Audio ST-01-PLUS overview
Aperçu du DOUK AUDIO ST-01-PLUS
1Vumetre
2BT / RCA / PHONO source indicator
3Multifunction button: power / input selection / volume control
4Bass control
5Treble control
6Bluetooth antenna
7RCA input
8RCA phono input
9AUX jack 3.5mm output
10Speaker terminal output
1124-48V DC power port via DC jack
Product typeIntegrated amplifier
Amplification chipTPA3255
Bluetooth chipQCC304X
Inputs1x Stereo RCA
1x Phono RCA input
OutputsSpeaker terminals
1x AUX jack 3.5mm output
Phono compatibilityMM Cartridge
Supported Bluetooth codecsSBC, AAC, aptX, aptX-LL, aptX-HD
Input sensitivityPhono: 5mV
RCA: 2V
Output power2x 120W @ 4 ohm (48V 5A)
2x 110W @ 6 ohm (48V 5A)
2x 102W @ 8 ohm (48V 5A)
Tone adjustmentBass/Treble : ±6dB
THD+N0.02% @ 1KHz
SNR≥ 107dB
Frequency response20Hz-20KHz (±1dB)
AUX jack 3.5mm output level2V
Power supply24-48V DC via DC jack (48V 5A power supply included)
Dimensions115 x 100 x 60mm
Weight673g
Package1x Douk Audio ST-01-PLUS
1x 48V 5A power supply
InputPhono
OutputSpeaker terminal
OutputJack 3.5mm
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)120.0
DOUK AUDIO ST-01-PLUS Phono Amplifier TPA3255 Bluetooth 5.2 aptX HD 2x120W 4 Ohm
The Douk Audio ST-01-Plus is a powerful and versatile phono amplifier. It's based on a TPA3255 amplifier chip for output power of up to 2x...
