FOSI AUDIO MC101 Stereo Bluetooth Amplifier
With its MC101 stereo amplifier, Fosi Audio unveils a small device at the crossroads of vintage and modernism. The MC101 features Bluetooth functionality, as well as a vintage look thanks to its rounded shape and VU meter on the front panel. Inside this device are not one, but two TI TPA3116 amplifier chips for an output power of 2x 60W @ 4 Ohm (THD+N=1%).
4.0 / 5
Reference : 18999
99,90 €tax incl.
83,25 € tax excl.
Shipping date: 16-07-2025.
FOSI AUDIO MC101 Stereo Amplifier 2x TPA3116 Bluetooth 5.3 2x100W @ 4 ohm
Fosi Audio MC101 picture
With its MC101 stereo amplifier, Fosi Audio unveils a small device at the crossroads of vintage and modernism. The MC101 features Bluetooth functionality, as well as a vintage look thanks to its rounded shape and VU meter on the front panel. Inside this device are not one, but two TI TPA3116 amplifier chips for an output power of 2x60W under 4 Ohm (THD+N=1%). On the rear panel of the Fosi Audio MC101, you'll find the essentials: a stereo RCA input, a speaker terminal output and a 3.5mm jack pre-out.
Fosi Audio MC101: Two TI TPA3116 amplifier chips
Thanks to its two TI TPA3116 amplifier chips, the Fosi Audio MC101 is able to develop a power of 2x60W under 4 ohm (THD+N=1%), with an SNR and dynamic range of more than 100dB. The 3.5mm pre-out jack output can also be used to connect an active subwoofer and set up a 2.1-channel audio system with immersive bass.
FOSI AUDIO MC101 picture
Fosi Audio MC101 front panel picture
Fosi Audio MC101: VUmeter and equalization
The highlight of the Fosi Audio MC101 is the VUmeter on the front panel, along with 3 potentiometers allowing you to adjust volume and equalize bass and treble to your liking. Bass is adjusted over a range of ±12dB and treble over a range of ±6dB.
Fosi Audio MC101 : Bluetooth 5.3
The Fosi Audio MC101's Bluetooth chip enables it to support SBC and AAC codecs extremely reliably, with an unobstructed range of up to 10m.
Bluetooth functionality of the Fosi Audio MC101
Example of a HiFi installation with the Fosi Audio MC101
Product typeStereo amplifier
Amplification chip2x TI TPA3116
Inputs1x Stereo RCA
Bluetooth
OutputsSpeaker terminals
1x Pre-out jack 3.5mm
Output power2x 60W @ 4 ohm (THD+N=1%)
2x 100W @ 4ohm (THD+N=10%)
Bluetooth Version5.3
Supported Bluetooth codecsSBC, AAC
SNR≥ 100dB
Dynamic range≥ 100dB
THD≤0.03%
Frequency response20Hz-20KHz (+1.8dB)
EqualizationBasses : ±12dB
Aigus : ±6dB
VUmeter
Power supply12V-24V DC
Dimensions126 x 120 x 42mm
Package1x Fosi Audio MC101 amplifier
1x 24V 4.5A power adapter with power cable
1x Bluetooth antenna
OutputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3116
Power (W)60.0
Musical mais...
Du souffle léger et chuintement dans les hauts parleurs avant de lancer musique, mal isolé pour éviter parasitages vers enceintes, a revoir.
This review has been posted for FOSI AUDIO MC101 Stereo Amplifier 2x TPA3116 Bluetooth 5.3 2x100W 4 ohm
With its MC101 stereo amplifier, Fosi Audio unveils a small device at the crossroads of vintage and modernism. The MC101 features...
