FOSI AUDIO V3-48V Stereo Class D Amplifier TPA3255 2x225W 4 Ohm
The V3 from Fosi Audio is a compact and powerful amplifier at a very affordable price. Despite its simplicity, the V3 amplifier uses high-quality audiophile components such as a TI TPA3255 amplifier chip and delivers up to 2x225W @ 4Ω.
4.8 / 5
Reference : 17954
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 14-05-2026.
FOSI AUDIO V3-48V
FOSI AUDIO V3 Amplificateur Stéréo Class D TPA3255 2x300W 4 Ohm
The V3 from Fosi Audio is a compact, powerful amplifier that also remains very affordable. Despite its simplicity, the V3 amplifier uses high-quality audiophile components such as a TI TPA3255 amplification chip, Japanese and German Elna and Wima capacitors and DIP8-mounted NE5532 AOPs, giving you the option of replacing them if you want a particular sound signature. This amplifier is ideal for integration into a HiFi system requiring high power, since it delivers up to 2x225W @ 4Ω. Connections include a stereo RCA input, speaker terminals and a 3.5mm pre-out jack.
A powerful amplification stage
The Fosi Audio V3 uses a TI TPA3255 amplification chip, which delivers true sound quality with class D efficiency and very low distortion. Coupled with audiophile components, the TI TPA3255 allows the V3 to maintain high stability even at very high power. In terms of OPA, the Fosi Audio V3 is equipped with DIP8-mounted NE5532, making them easy to replace. They can be replaced by MUSES02s, AOP2604APs or AOP2134PAs, for example.
Intelligent volume control
The volume control is based on a logarithm (Taper A pot), providing much finer control that is better adapted to the human ear. This makes the final listening experience more immersive and pleasant.
Efficient heat dissipation
The heat dissipation system of the Fosi Audio V3 allows it to be used at high power for extended periods without compromising its performance or causing harmful effects. In fact, the V3's enclosure incorporates vents on its upper and lower sides as well as an internal radiator. This innovative cooling system design greatly improves the airflow and heat dissipation of the Fosi Audio V3 amplifier.
Simple and effective connectivity
1Power indicator
2Power switch / Volume control
3Stereo RCA input
43.5mm pre-out Jack
5Speaker terminals
6Power plug DC 24V-48V
Test du FOSI AUDIO V3 par Audio Science Review
"The Fosi Audio V3 is well implemented and brings nice looks and design at a bargain price. Company is also quite receptive to customer input and is a delight to work with behind the scenes. I don't know what else we could ask for!"
Test du SMSL SU-9 par Audio Science Review
Product typeStereo class D Amplifier
Inputs1x Stereo RCA
Outputs1x Speaker terminals
1x 3.5mm pre-out jack
Amp. chipTI TPA3255
OPA2x NE5532
Output power2x 225W @ 4Ω (THD+N 1%)
2x 160W @ 8Ω (THD+N 1%)
2x 270W @ 4Ω (THD+N 10%)
2x 190W @ 8Ω (THD+N 10%)
Speaker impedance2Ω - 8Ω
Frequency response20Hz - 20kHz (±0.1dB)
SINAD≥ 88dB
THD0.003%
SNR≥ 110dB
Volume controlLogarithm A pot
Power supply24 - 48V DC
Dimensions166 x 105 x 35 mm
Package1x Fosi Audio V3
1x Power adapter 48V 5A
OutputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)225.0
13 reviews
Impressionnant !
Ils alimente avec poigne 2 Bass Shaker DAYTON AUDIO BST-300EX.
J'ai trouvé le combo parfait !!!
Je recommande
This review has been posted for FOSI AUDIO V3-48V Stereo Class D Amplifier TPA3255 2x225W 4 Ohm
RPQ imbattable ?
Au delà de mes attentes, drive parfaitement de vieilles Bibliothèques d'un rendement de 86dB !
Excellent !
Très bon son, pas le moindre souffle (il faut coller son oreille sur le HP aigu pour savoir que l'ampli est allumé); j'en ai 2 (bi-amplification active), ils sont allumés quasiment en permanence depuis bientôt 2 ans, avec alim 32 v le dessus de l'ampli est froid, avec alim de 48 v il est tiède; Autre avantage, quand on l'allume ou qu'on l'éteint il n'y a aucun plop, ce qui est un bonne nouvelle quand vous connectez directement un tweeter sur la sortie (ce que fait mais vous déconseille ...)
Un ampli intéressant, plein de vivacité et d'une écoute plaisante.
Lui laisser le temps de roder ses composants ...
En baissant trop le volume on tendance a l'eteidre.
En ce moment j’écoute "Dark side of the moon" pour préparer ma bolognaise...
En ce moment "Dark side of the moon" pour préparer ma bolognaise...
The V3 from Fosi Audio is a compact and powerful amplifier at a very affordable price. Despite its simplicity, the V3 amplifier uses high-quality...
