NAD C700 V2 Amplifier Streamer
The NAD C700 V2 is a remarkable connected amplifier that lets you enjoy a wide range of streaming sources directly amplified on speakers. Its amplification stage is based on a Hybrid Digital nCore UcD module, delivering up to 2x80W  4/8 ohms to the NAD C700 V2's speaker terminals. Its digital-to-analog conversion stage incorporates an ES9028 DAC chip for support of high-resolution PCM 24bit 192kHz sampling rates.
By buying this product you get 159 loyalty points
Reference : 20037
1 590,00 €tax incl.
1 325,00 € tax excl.
NAD C700 V2 Amplifier Streamer HybridDigital UcD DAC ES9028 2x80W 4/8 Ohm 24bit 192kHz MQA
NAD C700 V2 picture
The NAD C700 V2 is a remarkable connected amplifier that lets you enjoy a wide range of streaming sources directly amplified on speakers. Its amplification stage is based on a Hybrid Digital nCore UcD module, delivering up to 2x80W  4/8 ohms to the NAD C700 V2's speaker terminals. Its digital-to-analog conversion stage incorporates an ES9028 DAC chip for support of high-resolution PCM 24bit 192kHz sampling rates. The streamer also features an attractive color screen and the BluOS interface for easy, intuitive access to local or networked files via streaming services such as Amazon Music Ultra HD, Deezer, Qobuz, Tidal, Sptify Connect, Tidal Connect and more. Additional features include Airplay 2 and bi-directional Bluetooth, plus extensive connectivity including MM phono input, HDMI ARC input, RCA pre-out and subwoofer output. The C700 V2 is therefore capable of fulfilling numerous functions within a complete Hi-Fi installation, as well as being an excellent stand-alone device.
NAD C700 V2 picture
NAD C700 V2: nCore Hybrid Digital UcD amplification
The C700 V2 adopts nCore Hybrid Digital UcD amplification, very similar to the one used in its cousins, the M10 V2 and M10 V3. This amplification, in addition to offering superb performance with optimum SNR and ultra-low THD, enables output power of up to 2x80W whether the load impedance is 4 ohm or 8 ohm. Coupled with good bookshelf or floorstanding speakers, the NAD C700 V2 is capable of delivering dynamic, detailed and precise sound.
NAD C700 V2 picture
NAD C700 V2: new ES9028 DAC chip
The NAD C700 V2 conversion stage benefits from an ESS ES9028 DAC chip supporting high-resolution sampling rates up to PCM 24bit 192kHz and numerous formats such as MP3, AAC, WMA, FLAC and MQA.
NAD C700 V2 picture
NAD C700 V2: a gateway to streaming platforms
With its Wi-Fi 5 connection and RJ45 Ethernet port, the NAD C700 V2 acts as a true network player. It offers access to Amazon Music, Spotify, TIDAL, Deezer, Qobuz, HDTracks and numerous online radio stations, thanks to the BluOS Controller application for Android, IOS, macOS and Windows.
NAD C700 V2: Airplay 2 and two-way Bluetooth
Airplay 2 and Bluetooth enable you to receive and stream audio remotely. Bluetooth supports SBC, AAC, aptX and aptX HD codecs for reliable, stable transmission. What's more, Bluetooth transmission comes in very handy for those with Bluetooth-enabled headphones or earphones. Airplay 2, meanwhile, with the help of the BlueOS application, lets you set up a multiroom or home cinema system with up to 4.1 channels and BluOS-compatible speakers. The NAD C700 V2's compatibility with Dolby Surround and DIRAC Live (optional) ensures immersive, calibrated sound reproduction.
Airplay et Bluetooth logo
NAD C700 V2 overview
112V trigger output
2Infrared input
3Phono input
4RCA line input
5Pre-out RCA
6Phono GND
7Subwoofer output
8Coaxial input
9Toslink optical input
10HDMI eARC input
11Service port
12RJ45 Ethernet port
13USB-A input
14Service port
15Standby
16Speaker terminals
17Power input
Product typeAmplifier and streamer
AmplificationCCore Hybrid Digital UcD
DAC chipES9028
Inputs1x RCA analog
1x Phono input
1x Coaxial
1x Toslink optical
1x HDMI eARC
1x USB-A
Outputs1x RCA pre-out
1x Speaker terminal output
Other connectors1x Trigger 12V
1x Infrarouge
ConnectivityWiFi 5
Ethernet RJ45
Bluetooth
Airplay 2
Output power2x80W @ 4/8 ohm (ref. 20Hz-20kHz at THD+N nominal, both canal supplied)
THD+N> 84dB (A-weighted, input 500mV, ref. 1W output into 8 ohms)
SNR> 84dB (A-weighted, input 500mV, ref. 1W output into 8 ohms)
Cut-off power> 86 W (at 1kHz 8 ohms 0,1% THD)
> 102 W (at 1kHz 4 ohms 0,1% THD)
IHF dynamic power8 ohms : 100W
4 ohms : 125W
Damping factor> 90 (ref. 8 ohms, 20Hz to 20kHz)
Frequency response± 0,18dB (20Hz - 20kHz)
Tone controlTreble : ±6,0dB to 20kHz
Bass : ±6,0dB to 60Hz
Crosstalk> 93dB ( kHz)
> 72dB (10kHz)
Input sensitivity (for 80W, 8 ohms)Line input: 550 mV
Digital input: -12%FS
Supported sample ratesPCM up to 24bit 192kHz
Supported bluetooth codecsSBC, AAC, aptX, aptX HD
System compatibilityMicrosoft
Windows XP, 2000, Vista, 7, 8 to current Windows operating systems
MacOS
ApplicationBluOS: android, IOS, Windows, MacOS
subwoofer output
Maximal output level4Vrms (ref 0,0032% THD+N 100Hz)
SNR> 106dB (20Hz-20kHz, ref 1V out)
THD+N> 0,006% (20Hz-200Hz, ref 1,964V)
Output impedance600 ohms
Power100-120V / 220-240V 50/60Hz
Standby power consumption> 0.5W
Dimensions218 x 96 x 266 mm
Weight4.8kg
Package1x NAD C700 V2
1x Remote control
1x Power cable
InputPhono
InputHDMI ARC
OutputSubwoofer
OutputSpeaker terminal
DAC / ADC ChipES9028PRO
Max sampling rate192kHz
Max sampling rateMQA
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)80.0
Remote ControlYes
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify Connect
The NAD C700 V2 is a remarkable connected amplifier that lets you enjoy a wide range of streaming sources directly amplified on speakers. Its...
