By buying this product you get 159 loyalty points
The NAD C700 V2 is a remarkable connected amplifier that lets you enjoy a wide range of streaming sources directly amplified on speakers. Its amplification stage is based on a Hybrid Digital nCore UcD module, delivering up to 2x80W 4/8 ohms to the NAD C700 V2's speaker terminals. Its digital-to-analog conversion stage incorporates an ES9028 DAC chip for support of high-resolution PCM 24bit 192kHz sampling rates. The streamer also features an attractive color screen and the BluOS interface for easy, intuitive access to local or networked files via streaming services such as Amazon Music Ultra HD, Deezer, Qobuz, Tidal, Sptify Connect, Tidal Connect and more. Additional features include Airplay 2 and bi-directional Bluetooth, plus extensive connectivity including MM phono input, HDMI ARC input, RCA pre-out and subwoofer output. The C700 V2 is therefore capable of fulfilling numerous functions within a complete Hi-Fi installation, as well as being an excellent stand-alone device.
The C700 V2 adopts nCore Hybrid Digital UcD amplification, very similar to the one used in its cousins, the M10 V2 and M10 V3. This amplification, in addition to offering superb performance with optimum SNR and ultra-low THD, enables output power of up to 2x80W whether the load impedance is 4 ohm or 8 ohm. Coupled with good bookshelf or floorstanding speakers, the NAD C700 V2 is capable of delivering dynamic, detailed and precise sound.
The NAD C700 V2 conversion stage benefits from an ESS ES9028 DAC chip supporting high-resolution sampling rates up to PCM 24bit 192kHz and numerous formats such as MP3, AAC, WMA, FLAC and MQA.
With its Wi-Fi 5 connection and RJ45 Ethernet port, the NAD C700 V2 acts as a true network player. It offers access to Amazon Music, Spotify, TIDAL, Deezer, Qobuz, HDTracks and numerous online radio stations, thanks to the BluOS Controller application for Android, IOS, macOS and Windows.
Airplay 2 and Bluetooth enable you to receive and stream audio remotely. Bluetooth supports SBC, AAC, aptX and aptX HD codecs for reliable, stable transmission. What's more, Bluetooth transmission comes in very handy for those with Bluetooth-enabled headphones or earphones. Airplay 2, meanwhile, with the help of the BlueOS application, lets you set up a multiroom or home cinema system with up to 4.1 channels and BluOS-compatible speakers. The NAD C700 V2's compatibility with Dolby Surround and DIRAC Live (optional) ensures immersive, calibrated sound reproduction.
1 | 12V trigger output |
2 | Infrared input |
3 | Phono input |
4 | RCA line input |
5 | Pre-out RCA |
6 | Phono GND |
7 | Subwoofer output |
8 | Coaxial input |
9 | Toslink optical input |
10 | HDMI eARC input |
11 | Service port |
12 | RJ45 Ethernet port |
13 | USB-A input |
14 | Service port |
15 | Standby |
16 | Speaker terminals |
17 | Power input |
Product type | Amplifier and streamer |
Amplification | CCore Hybrid Digital UcD |
DAC chip | ES9028 |
Inputs | 1x RCA analog 1x Phono input 1x Coaxial 1x Toslink optical 1x HDMI eARC 1x USB-A |
Outputs | 1x RCA pre-out 1x Speaker terminal output |
Other connectors | 1x Trigger 12V 1x Infrarouge |
Connectivity | WiFi 5 Ethernet RJ45 Bluetooth Airplay 2 |
Output power | 2x80W @ 4/8 ohm (ref. 20Hz-20kHz at THD+N nominal, both canal supplied) |
THD+N | > 84dB (A-weighted, input 500mV, ref. 1W output into 8 ohms) |
SNR | > 84dB (A-weighted, input 500mV, ref. 1W output into 8 ohms) |
Cut-off power | > 86 W (at 1kHz 8 ohms 0,1% THD) > 102 W (at 1kHz 4 ohms 0,1% THD) |
IHF dynamic power | 8 ohms : 100W 4 ohms : 125W |
Damping factor | > 90 (ref. 8 ohms, 20Hz to 20kHz) |
Frequency response | ± 0,18dB (20Hz - 20kHz) |
Tone control | Treble : ±6,0dB to 20kHz Bass : ±6,0dB to 60Hz |
Crosstalk | > 93dB ( kHz) > 72dB (10kHz) |
Input sensitivity (for 80W, 8 ohms) | Line input: 550 mV Digital input: -12%FS |
Supported sample rates | PCM up to 24bit 192kHz |
Supported bluetooth codecs | SBC, AAC, aptX, aptX HD |
System compatibility | Microsoft Windows XP, 2000, Vista, 7, 8 to current Windows operating systems MacOS |
Application | BluOS: android, IOS, Windows, MacOS |
subwoofer output | |
Maximal output level | 4Vrms (ref 0,0032% THD+N 100Hz) |
SNR | > 106dB (20Hz-20kHz, ref 1V out) |
THD+N | > 0,006% (20Hz-200Hz, ref 1,964V) |
Output impedance | 600 ohms |
Power | 100-120V / 220-240V 50/60Hz |
Standby power consumption | > 0.5W |
Color | Black |
Dimensions | 218 x 96 x 266 mm |
Weight | 4.8kg |
Package | 1x NAD C700 V2 1x Remote control 1x Power cable |
Input | RCA |
Input | Optical |
Input | HDMI ARC |
Input | USB |
Input | SPDIF |
Input | Phono |
Output | Speaker terminal |
Output | RCA |
Output | Subwoofer |
DAC / ADC Chip | ES9028PRO |
Max sampling rate | MQA |
Max sampling rate | 192kHz |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | Hypex Ncore |
Power (W) | 80.0 |
Remote Control | Yes |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Deezer |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Spotify |
Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Amazon Music |
Streaming services & Network protocols | AirPlay |
