By buying this product you get 33 loyalty points
Amplifier Class D ICEpower 2x125W / 1x500W 4 Ohm
Sabaj unveils with the A8 a compact and powerful Class D amplifier, based on an ICEpower amplifier chip, capable of a clear and faithful reproduction. Easy to use, its connectivity will allow you to use its RCA input for a stereo system or its balanced XLR input to make it work in bridged mono and have a high output power. The latter can also be used to connect a passive subwoofer or to connect two A8s and enjoy a high power stereo amplifier. The output is done on classic speaker terminals. The A8's solid industrial style enclosure is optimized to efficiently dissipate the heat generated by the unit's components.
Product type | Amplifier |
Amplification type | Class D |
Amplification board | ICEpower |
Inputs | 1x Stereo RCA 1x Mono XLR |
Output | Speaker terminals |
Output power | 2x125W @ 4Ω 2x68W @ 8Ω 1x500W @ 4Ω 1x270 @ 8Ω |
THD+N | 0.002% |
SNR | 117dB |
Channel separation | 96dB |
Input senstivity | 280mV |
Input impedance | 47kΩ |
Consumption | 40W |
Standby consumption | < 0.6W |
Dimensions | 200 x 59 x 208mm |
Weight | 1470g |
Color | Silver |
Input | XLR |
Input | RCA |
Output | Speaker terminal |
Color | Silver |
Channel | 2 (Stereo) |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | Ice Power |
Power (W) | 125.0 |
Power (W) | 500.0 |
