By buying this product you get 44 loyalty points
SMSL unveils its PA200, a singular amplifier somewhere between a power amplifier and an integrated amplifier. The latter is capable of operating both in stereo with volume control and in mono as a pure power amplifier, and relies on Infineon GaN FET transistors. It offers up to 2x160W under 4 Ohm power via its stereo RCA input, and up to 1x400W under 4 ohm via its mono XLR input. Inside the PA200 are audiophile components such as a PGA2311 digital volume control chip, switch-mode power supply and gold-plated connectors. Outputs are via speaker terminals, and a remote control is available for remote operation.
Infineon GaN FET transistors enable the PA200 to develop substantial output power, whether in stereo or mono. Indeed, the stereo RCA input offers up to 2x160W under 4 ohm power, while the XLR input offers up to 1x400W under 4 ohm power. With a THD+N of just 0.003%, the PA200 can provide the soundtrack to a beautiful space, while preserving the sound reproduction of your favorite recordings.
A Texas Instrument PGA3211 digital volume control chip controls the output volume if the RCA input is used.
Please note that volume control is only available with the stereo RCA input. If you use the mono XLR input, the PA200 will not allow you to control the output volume.
As mentioned above, when used with mono XLR, the SMSL PA200 has no volume control, and therefore functions as a pure power amplifier. This enables it to gain considerable power in a dual mono installation with two PA200 amplifiers.
The performance and form factor of the SMSL PA200 make it ideal for use with the SMSL D200 DAC and SMSL PL200 CD player.
1 | Stereo RCA input |
2 | Mono XLR input |
3 | Speaker terminal output |
4 | IEC power input 100-240V |
Product type | Amplifieur |
Amplification componant | Infineon GaN FET transistors |
Inputs | 1x Stereo RCA input 1x Mono XLR input |
Output | 1x Speaker terminal output |
THD+N | 0.003% |
SNR | 109dB |
Channel separation | 75dB |
Input sensitivity | RCA stereo: 0.68Vrms/22kOhm XLR mono: 2.1Vrms/22kOhm |
Output power | Stereo : 2x160Wrms @ 4 Ohm / 2x85Wrms @ 8 Ohm Mono : 1x400Wrms @ 4 Ohm / 1x250W @ 8 Ohm |
Power supply | 100-240V AC |
Power consumption | 40W Standby: < 0.5W |
Dimensions | 220 x 45.9 x 175mm |
Weight | 1.44kg |
Color | Silver |
Package | 1x PA200 amplifier 1x Remote control 1x Power supply cable |
Input | RCA |
Input | XLR |
Output | Speaker terminal |
Color | Gray |
Color | Silver |
Channel | 2 (Stereo) |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | Transistors |
Power (W) | 400.0 |
Power (W) | 160.0 |
Remote Control | Yes |
