By buying this product you get 109 loyalty points
Tonewinner unveils an all-in-one device with its AD89D Class AB integrated amplifier. This 2.1-channel amplifier features a CD player, high-fidelity Bluetooth reception and an HDMI ARC port. Powerful and versatile, the Tonewinner AD-89D is capable of delivering up to 2x 130W at 8 ohm, and fulfills the functions of CD player, multimedia player/DAC and integrated amplifier or power amplifier. Its wide range of connectors makes it easy to integrate into any audio system.
This Tonewinner amplifier adopts a high-speed, low-distortion Class A amplifier circuit with strong drive capability and beautiful dynamics. It's also worth mentioning that the internal structure separates the power stage from the input and signal processing stages. Left and right channels are also processed independently. This structure greatly reduces the risk of interference and noise generation. On the power supply side, the AD89-D uses a 350VA toroidal transformer and 40000uF capacitors. No less than 8 high-precision, high-power matched tubes are used for the output stage.
The AD-89D supports WAV, Flac and APE files via U disk and TF card up to 128 GB for lossless music file quality. In addition, the high-quality CD drive on the front panel absorbs shocks and ensures reliable, stable playback quality.
The AD-89D amplifier's Bluetooth functionality lets you enjoy stable, low-distortion, low-latency wireless transmission, so you can connect your smartphone or tablet.
Among its digital inputs, the AD-89D features a USB-B port with digital interface supporting up to PCM 24bit 48kHz. So you can enjoy high-resolution streams via a source such as your computer.
The HDMI ARC port and subwoofer output allow the AD-89D to be integrated into a home theater setup, for more immersive sound thanks to an active subwoofer.
U-shaped rings on the AD-89D's connectors enable it to be used as an integrated amplifier. Removing these rings simply allows it to be used as a pure power amplifier within a complete sound system. This amplifier's immense versatility means it can meet most of your needs.
A dedicated control app makes it easy to navigate between your different sources. The mobile app interface also features a TV settings menu. It supports up to 8 levels of file folder management, making it particularly practical for playback of files on U discs and TF cards.
| 1 | 3x Coaxial input |
| 2 | Toslink optical input |
| 3 | Bluetooth reception antenna |
| 4 | TF card slot |
| 5 | USB-B input |
| 6 | HDMI ARC input |
| 7 | Speaker terminals |
| 8 | Subwoofer output |
| 9 | PRE OUT/ AMP IN |
| 10 | 3x Analog RCA stereo input |
| 11 | IEC power supply |
| Specifications | |
| Product type | Integraterd amplifier |
| Amplification type | Class AB |
| Channel numbers | 2.1 |
| Inputs | 1x CD player 1x USB-B 1x Optical Toslink 3x SPDIF coaxial 1x HDMI ARC 3x RCA stereo Bluetooth TF card slot U disk (up to 128GB) |
| Outputs | Speaker terminals Subwoofer output |
| Output power | 2x 130W (8Ω, 1kHz) |
| Input impedance | 10kohm |
| Frequency response | 10Hz-50kHz (+1/-3dB) |
| THD | ≤ 0.05%(A weighted, analog direct) |
| SNR | ≥ 95dB(A weighted, analog direct) |
| Global gain | ≥ 41dB (A weighted, analog direct) |
| General | |
| Power supply | 110V-115V (60Hz) / 220V-230V (50Hz) |
| Max. power consumption | 450W / 8Ω |
| Dimensions | 430×397×151mm |
| Net weight | 12.7Kg |
| Package | 1x Tonnewinner AD-89D amplifier |
| Input | USB |
| Input | XLR |
| Input | Optical |
| Input | SD Card |
| Input | RCA |
| Input | SPDIF |
| Input | Bluetooth |
| Input | HDMI ARC |
| Output | Subwoofer |
| Output | Speaker terminal |
| Color | Black |
| Channel | 2.1 |
| Class | Class A / AB |
| Amplifier chip | N/A |
| Power (W) | 130.0 |
| Remote Control | No |
