TONEWINNER AD-99D Class AB Stereo Amplifier Bluetooth 2x290W 4 Ohm
15%
As imposing in appearance as it is in power, the Tonewinner AD-99D is a powerful, versatile and robust Class AB stereo integrated amplifier. It delivers a pure and delicate sound, with a beautiful dynamic and richness of sound. It uses two balanced modules equipped with Toshiba transistors. It is completed by an efficient and reliable power supply stage and by a particularly complete connectic.
Reduced price!
Reference : 17347
Limited time offer:
1 390,00 €tax incl.
-15%
1 181,50 €tax incl.
984,58 € tax excl.
Last items in stock !
Shipping date: 08-07-2025.
Tonewinner AD-99D
Tonewinner AD-99D Amplificateur Stéréo Class AB Bluetooth 2x290W 4Ω
A powerful Class AB amp
The two amplifier modules of the AD-99D are placed on both sides of the device, on the side walls of the amplifier, directly leaning against the large heat sinks. These embed four pairs of Toshiba TTC5200 and TTA1943 transistors to deliver a power of 2x 190W under 4Ω or 2x 290W under 8Ω. A reliable architecture capable of a musical and lively sound reproduction.
AD1955 DAC
With many digital inputs, the Tonewinner AD-99D also has a dedicated digital to analog conversion section. This one uses a DAC AD1955 24bit 192kHz chip, allowing it to decode efficiently the digital streams in order to provide the most faithful sound possible.
From integrated amplifier to power amp
The Pre-Out output and the Amp In input of the AD-99D, which are connected to each other for operation as an integrated amplifier, can be disconnected. In this case, the AD-99D becomes an independent power amplifier and can be integrated into a more complex system.
A consistent power supply
The power supply stage of the Tonewinner AD-99D is mainly composed of a large 550VA toroidal transformer as well as a module integrating eight large filter capacitors for a total capacity of 69400pF. This allows to provide all the circuits with a clean electrical signal and to meet important and sudden energy needs.
Total insulation
Each section of the Tonewinner AD-99D is physically isolated from the others to greatly limit interference that can affect signal quality.
An abundance of connectivity
With its many inputs, the AD-99D is very versatile. It will be able to integrate without difficulty into the vast majority of audio systems. It offers, as inputs, USB-B (USB Audio) and USB-A (USB Host), a slot for Micro SD card, HDMI ARC, optical and coaxial for the digital section as well as stereo RCA for the analog part. This connectivity is completed by a Bluetooth wireless connectivity, allowing to easily broadcast its music remotely, from a smartphone or a tablet for example.
1USB-A input (USB Host)
2Bluetooth antenna
3USB-B input (USB Audio)
4Micro SD slot
5HDMI ARC input
6Optical Toslink input
7Coaxial inputs
812V trigger input/output
9Right channel speaker output
10Subwoofer output
11Pre-Out output
12Amp-In input
13Stereo RCA inputs
14Power input
15Left channel speaker output
Product typeAmplifier
Amplification typeClass AB
Number of channelsStereo (2)
InputsBluetooth
1* USB-B (USB Audio)
1* Slot Micro SD
1* HDMI ARC
1* Optical Toslink
3* Coaxial
1* USB-A (USB Host)
3* Stereo RCA
1* 12V Trigger input
OutputsSpeaker terminals
1* Subwoofer output on stereo RCA
1* 12V Trigger output
Output power2*290 @ 4Ω
2*190 @ 8Ω
Tone controlBass
Treble
THD≤ 0.01% (1kHz)
Input impedance10kΩ
Channel separation≥ 80dB
SNR≥ 100dB (A-Weighted)
Frequency response10Hz-90kHz (+1/-3dB)
Gain> 42dB
Supply voltage110-230VAC 50/60Hz
Dimensions (L*P*H)445*456*218mm
Net weight24.1kg
ColorBlack and silver
Package1x Tonewinner AD-99D
1x Remote control (CR2016 battery not included)
1x Power cable
InputHDMI
InputMicro SD
OutputSubwoofer
OutputSpeaker terminal
ColorSilver
Channel2.1
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)290.0
ToneWinner AD-99D
A la recherche d'un ampli de remplacement pour driver mes Aria 948, le Tonewinner AD-99D m'a été conseillé par l'équipe Audiophonics, que je remercie au passage pour leur patience, car il correspondait a mes critères de qualité de connectivité et de budget.
Après plus d'un mois d'utilisation je peux dire qu'il met en valeur ces superbes enceintes. Tout le registre est présent, même les graves les plus profonds se révèlent. Aucune fatigue a l'écoute quel que soit le style.
La puissance ce beau bébé de 21Kg en classe A en a revendre et pourtant il ne chauffe absolument pas ni ne consomme trop, je m'attendais a bien plus vu la taille des radiateurs et de l'alim. La connectique est plus que suffisante pour mon usage. Seul bémol la télécommande très cheap ne permet pas un accès direct aux entrées. Peut être un upgrade de firmware pourrait apporter un confort a ce niveau, notamment avec une télécommande programmable. J'en ai profité pour changer le câble d'alim, Audiophonics blindé, et les câbles d'enceintes, Mogami, tant que faire.
Je ne connaissais pas cette marque et jusqu’à présent je suis franchement satisfait de mon achat.
This review has been posted for TONEWINNER AD-99D Class AB Stereo Amplifier Bluetooth 2x290W 4 Ohm
As imposing in appearance as it is in power, the Tonewinner AD-99D is a powerful, versatile and robust Class AB stereo integrated amplifier. It...
