TOPPING MX3S Class D Amplifier Infineon Headphone Amplifier DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Silver
20%
The Topping MX3S is a true swiis army knife of audio, acting as both an amplifier and a headphone amplifier with integrated AK4377 DAC and Bluetooth receiver. An ideal model for a small or medium-sized listening room and capable of a dynamic, precise and faithful reproduction.
4.0 / 5
Reduced price!
Reference : 17422
Limited special offer
239,00 €tax incl.
-20%
191,20 €tax incl.
159,33 € tax excl.
Last items in stock !
Shipping date: 30-04-2025.
Topping MX3S
Topping MX3S Amplificateur Class D Infineon Amplificateur Casque DAC Bluetooth aptX Adaptive 2x50W 4Ω 24bit 192kHz Argent
The Topping MX3S is a true swiis army knife of audio, acting as both an amplifier and a headphone amplifier with integrated AKM AK4377 DAC and Bluetooth receiver. An ideal model for a small or medium-sized listening room and capable of a dynamic, precise and faithful reproduction.
MX3S
MX3
THD+N @ 1kHz, A-Weighted (headphone output)
< 0.003% @ 270mW, 32 Ohm
< 0.001% @ 30mW, 300 Ohm
< 0.006% @ 130mW 32 Ohm
SNR @ Max out 1kHz, A-Weighted (headphone output)
115dB
103dB
Gain (headphone output)
2dB(Vrms/FS) @ G=L
14.8dB(Vrms/FS) @ G=H
11.6dB
Noise @ A-Weighted (headphone output)
< 2.0µVrms @ G=L
< 7.0µVrms @ G=H
< 18.0µVrms
Output power (headphone output)
2*700mW @ 32 Ohm, THD+N < 1%
2*400mW @ 64 Ohm, THD+N < 1%
2*100mW @ 300 Ohm THD+N < 1%
2*257mW @ 32 Ohm THD+N < 1%
2*42mW @ 300 Ohm, THD+N < 1%
SNR @ BTL, Max out, 1kHz, A-Weighted (sortie HP)
110dB
91dB
Noise @ BTL, A-Weighted (sortie HP)
< 60µVrms @ G=L
< 100µVrms @ G=H
< 500µVrms
An efficient Class D amplifier
The amplifier section of the MX3S uses an Infineon Merus Class D chip allowing it to deliver a power of 2x50W under 4Ω with a high efficiency higher than 90%. It also offers a characteristic restitution marked by a beautiful clarity and precision. The MX3S also offers a two-level gain control allowing it to adapt to your listening system.
Bluetooth
In addition to its complete connectivity, the Topping MX3S provides a Bluetooth receiver, allowing a remote broadcast of your music, from a smartphone or a tablet for example. The chip used supports the aptX, aptX HD and aptX Adaptive transmission codecs, promoting quality wireless sound reproduction.
Subwoofer output
With its RCA format subwoofer output, the MX3S can be used to set up a 2.1 audio system. The use of a subwoofer allows you to achieve deep and punchy bass.
Signal detection
The digital inputs of the Topping MX3S have an automatic detection of the input signal. This allows the unit to be turned on automatically when it receives an audio signal and to be turned off if no valid signal is received for one minute.
Built-in equalizer
In order to adapt to your listening and your audio system, the Topping MX3S benefits from a built-in equalizer. It allows you to adjust the bass and treble levels over a range of -10dB to +10dB.
Product typeAmplifier
Headphone amplifier
DAC
InputsBluetooth
1* Stereo RCA
1* Coaxial
1* Optical Toslink
1* USB-C
OutputsStereo speaker output
1* Subwoofer output on mono RCA
1* Jack 3.5mm headphone output
Supported sampling ratesPCM up to 24bit 192kHz
Supported Bluetooth codecsAAC, SBC, aptX, aptX-HD, aptX Adaptive
Headphone amplifier specifications
InputUSB / Optical / CoaxialAUXBluetooth (aptX Adaptive)
THD+N @ 1kHz (A-wt)< 0.003% @ 270mW, 32Ω
< 0.001% @ 30mW, 300Ω
< 0.002% @ 30mW, 300Ω
SNR @ max out, 1kHz (A-wt)115dB127dB115dB
Dynamic range @ 1kHz (A-wt)115dB127dB115dB
Frequency response20Hz-20kHz (+0.1dB/-0.3dB)
20Hz-40kHz (+0.1dB/-1.0dB)
20Hz-20kHz (+0dB/-2dB)
Output level3.4Vpp @ G=L
15.6Vpp @ G=H
10.2Vpp @ G=L
14.4Vpp @ G=H
3.4Vpp @ G=L
15.6Vpp @ G=H
Noise (A-wt)< 2.0µVrms @ G=L
< 7.0µVrms @ G=H
< 2.0µVrms @ G=L
< 7.0µVrms @ G=H
< 2.0µVrms @ G=L
< 7.0µVrms @ G=H
Crosstalk @ 1kHz-90dB
Input sensitivity0dBFS @ G=L
0dBFs @ G=H
4.2Vrms @ G=L
1.2Vrms @ G=H
0dBfS @ G=L
0dBFs @ G=H
Gain2dB (Vrms/FS) @ G=L
14.8dB (Vrms/FS) @ G=H
-0.2dB @ G=L
12.6dB @ G=H
2dB (Vrms/FS) @ G=L
Output impedance< 0.5Ω
Output power2*700mW @ 32Ω, THD+N < 1%
2*400mW @ 62Ω, THD+N < 1%
2*100mW @ 300Ω, THD+N < 1%
Load impedance> 8Ω
Amplifier specifications
THD+N @ 1kHz (A-wt)< 0.005% @ 5W, 4Ω
< 0.004% @ 5mW, 8Ω
SNR @ max output, 1kHz (A-wt)110dB
Dynamic range @ 1kHz (A-wt)110dB
Frequency response20Hz-20kHz (+0.1dB/-0.-dB)
20Hz-40kHz (+0.1dB/-1.5dB)
Output level40Vpp @ 4Ω
44Vpp @ 8Ω
Noise (A-wt)< 60µVrms @ G=L
< 100µVrms @ G=H
Input sensitivity-2.0dBFS @ G=L
-8.0dBFs @ G=H
1.0Vrms @ G=L
0.5Vrms @ G=H
-2.0dBfS @ G=L
-8.0dBFs @ G=H
Gain26.5dB (Vrms/FS) @ G=L
32.5dB (Vrms/FS) @ G=H
24dB @ G=L
30dB @ G=H
Output impedance< 0.2Ω
Output power2*62W @ 4Ω, THD+N < 10%
2*50mW @ 4Ω, THD+N < 1%
2*40W @ 8Ω, THD+N < 10%
2*30W @ 8Ω, THD+N < 1%
Load impedance4-8Ω
Supply voltage26VDC (power supply included)
Dimensions (L*P*H)120*165*40mmmm
ColorSilver
Package1* Topping MX3S
1* Power adapter
1* Power cable
1* USB cable
1* Remote control
1* Bluetooth antenna
OutputJack 3.5mm
OutputSpeaker terminal
OutputSubwoofer
ColorSilver
Channel2 (Stereo)
Amplifier chipN/A
Power (W)50.0
Remote ControlYes
My travel partner
Works fine and this is my travel partner, used with a pair of Ino Audio piXM.
The only issue I have is the low level of amplifying when running blue tooth from my Android. When serving by USB-C from Android one gets much more power out and far better sound as well.
This review has been posted for TOPPING MX3S Class D Amplifier Infineon Headphone Amplifier DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Silver
The Topping MX3S is a true swiis army knife of audio, acting as both an amplifier and a headphone amplifier with integrated AK4377 DAC and...
