WiiM AMP Stereo Network Amplifier Grey
The WiiM Amp is an amplifier and streamer that's as compact as it is versatile and high-performance! It lets you distribute your music extremely simply via DLNA, AirPlay 2, Bluetooth (bidirectional) or Chromecast. So you can easily access your music library, whether it's stored on a computer, NAS or smartphone. What's more, control of the device and playback is made easy with the WiiM Home mobile app.
By buying this product you get 36 loyalty points
Reference : 18387
369,00 €tax incl.
307,50 € tax excl.
Shipping date: 16-07-2025.
WiiM AMP TPA3255 Class D Stereo Amplifier WiFi DLNA AirPlay 2 Chromecast Bluetooth 5.0 2x100W 4 Ohm Grey
WiiM AMP: Main view
The WiiM Amp is an amplifier and streamer that's as compact as it is versatile and high-performance! It lets you distribute your music extremely simply via DLNA, AirPlay 2, Bluetooth (bidirectional) or Chromecast. So you can easily access your music library, whether it's stored on a computer, NAS or smartphone. What's more, control of the device and playback is made easy with the WiiM Home mobile app. The app also gives you access to your favorite streaming platforms, such as Spotify, Tidal, Deezer and Qobuz.
On the amplification side, we find a high-efficiency Class D circuit TPA3255, capable of developing a comfortable power of 2x100W into 4Ω or 2x60W into 8Ω.
WiiM AMP : Network & Bluetooth playback
To enable you to enjoy your music remotely, the WiiM Amp integrates a streamer. The connection can be made via WiFi or RJ45 Ethernet. DLNA, AirPlay 2, Spotify Connect and Chromecast transmission protocols are supported. So you can easily access all the music stored on your network, whether on a computer, NAS or smartphone. This connectivity also lets you enjoy your favorite music streaming applications.
Bluetooth 5.0 wireless connectivity is also available. Bi-directional, it lets you stream music from a smartphone, for example, but also pair the WiiM Amp with Bluetooth headphones or speakers.
WiiM Amp Amplificateur Connecté WiFi DLNA AirPlay 2 Chromecast Bluetooth 5.0 2x100W 4 Ohm
WIIM AMP : Streaming apps
Once connected, the WiiM Amp will give you access to numerous music streaming applications such as Spotify, Deezer, Tidal, Qobuz, Amazon Music, Apple Music and Napster. You can also enjoy webradios such as iHeartRadio and TuneIn.
WIIM AMP : Efficient amplification
The WiiM Amp's Class D amplifier TPA3255 stage enables it to develop 2x100W into 4Ω or 2x60W into 8Ω, and all with high efficiency. This makes it ideal for powering bookshelf speakers or small columns. What's more, its careful, optimized design enables the amplifier to deliver precise, dynamic sound reproduction. What's more, it's possible to adapt the sound of the device thanks to numerous predefined equalization profiles and a 10-band parametric equalizer.
WiiM Amp : DAC and amplification chips
WiiM AMP : Outstanding sound quality
Enjoy excellent sound quality with WiiM AMP. The combination of an ESS ES 9018K2M DAC and a TI TPA 3255 amplifier chip delivers excellent performance, with a THD+N of just 0.002% (-93dB) and an SNR of 98dB at 5W. The WiiM offers precise, detailed reproduction.
WiiM AMP ; A complete range of connectors
In addition to its wireless connectivity, the WiiM Amp offers a comprehensive range of connectors, enabling it to integrate with the vast majority of audio systems. Inputs include stereo RCA and Toslink optical, as well as HDMI ARC for connecting a TV, and USB-A for playing music from a storage device (USB key or hard disk). Output is via speaker terminals that accept banana plugs. The signal can also be distributed to a subwoofer via its subwoofer output.
WiiM Amp Amplificateur Connecté WiFi DLNA AirPlay 2 Chromecast Bluetooth 5.0 2x100W 4 Ohm<span id=
1HDMI ARC input
2Ethernet RJ45 plug
3RCA input
4Speaker outputs
5Power input
6USB-A plug (USB Host)
7Optical Toslink input
8Subwoofer output
WiiM AMP ; Multiroom integration
The WiiM Amp can be used as a stand-alone unit, or combined with other units in a multiroom system. This makes it possible to distribute music throughout the home from a centralized control point, via the WiiM Home mobile application. Playback and volume can then be managed either synchronously for all devices, or independently for each piece of equipment.
Multiple devices can be linked in multiroom mode with any compatible LinkPlay device, or with AVS Multiroom and AirPlay 2 technologies.
WiiM AMP : Control application, remote control and voice assistants
The ergonomic, intuitive WiiM Home application gives you remote control of your WiiM Amp and music playback. It's also the access point for compatible streaming services.
The device can also be used completely independently, thanks to the remote control.
Finally, the WiiM Amp is compatible with Google Assistant, Amazon Alexa and Siri voice assistants, the WiiM Amp can be controlled by voice by linking it to the connected speaker of one of these systems or by using the microphone built into the remote control.
WiiM AMP : Voice control via Bluetooth remote control
The WiiM AMP is easy to control by voice, thanks to the included Bluetooth remote control with microphone and Alexa voice assistant. This means you can control music playback and volume levels in a perfectly intuitive way.
WiiM AMP Remote control
Discover the Wiim Amp test by Audio Science Review (Amir)
"The WiiM Amp is a very well executed streaming, multi-room amplifier. It easily plays against big boys of streaming despite lacking their name recognition. Objective performance is very good for the class."
logo Audio Science Review
Product typeAmplifier and streamer
Amplification typeClass D TPA3255
DAC chipESS SABRE ES9018K2M
InputsWiFi
Bluetooth
1x Stereo RCA
1x Optical
1x HDMI ARC
1x USB-A
1x HDMI ARC
1x Ethernet RJ45
OutputsSpeaker terminals
1x Subwoofer output
Output power2x60W @ 8Ω
2x100W @ 4Ω
Supported network protocolsAirPlay 2
DLNA
Chromecast
Control appWiiM Home
Compatible voice assistantsAmazon Alexa
Google Assistant
Siri
Dimensions190*60*190mm
ColorGrey
Package1x WiiM Amp
1x Remote control
1x Power cable
InputRJ45
InputHDMI ARC
InputWiFi
OutputSpeaker terminal
OutputBluetooth
OutputCoaxial SPDIF
DAC / ADC ChipNC
Max sampling rateNC
ColorGray
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)100.0
Remote ControlYes
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsChromecast
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
3 reviews
Exelent
Rapport qualité prix incroyable.
La mise en route est facile et rapide.
La fonction de calibrage du caisson est très efficace et m’a enfin permis de coupler mes enceintes avec mon caisson.
Seul la fonction calibrage de la pièce m’a semblé pas très pertinente lors de mes essais en dénaturant la personnalité des enceintes.
This review has been posted for WIIM AMP TPA3255 Class D Stereo Amplifier WiFi DLNA AirPlay 2 Chromecast Bluetooth 5.0 2x100W 4 Ohm Grey
Excellent résultat à un prix contenu
Le WiiM Amp est associé à des enceintes bibliothèques Sonus Faber Lumina II, et Qobuz est la source audio principale (connexion filaire Ethernet).
Le son obtenu est excellent avec de nombreux styles de musique, en particulier après activation et réglage de l'EQ (equalizer). J'ai trouvé le son un peu trop "clinique" à mon goût avec l'EQ coupé.
Mes enceintes étant en 4 Ohms, il y a une grande réserve de puissance et l'ampli ne chauffe guère à volume d'ambiance ou soutenu.
L'application WiiM Home est facile et agréable à utiliser. Le pilotage "Chromecast" depuis le Web Player Qobuz sur ordinateur fonctionne également parfaitement.
Excellent product
Very good all-in-one product, it ticks almost all boxes for my use case. One of the few on the market with a proper subwoofer out with lowpass/highpass filters. High-quality measurments reported by several testers.
Excellent performance/price ratio.
The WiiM Amp is an amplifier and streamer that's as compact as it is versatile and high-performance! It lets you distribute your music...
