WONDOM AA-AS32157 Amplifier Tripath TA2024 Class D 2 x 15W / 4 Ohm
Wondom proposes here a TA2024 Clas D amplifier delivering a power of 2x15W under 4Ω, ideal for any secondary or auxiliary HiFi installation. Thanks to its compact design, its elegant case and its great ease of use, this amplifier will allow you to listen to your favorite songs on your audio systems with extreme simplicity.
4.7 / 5
Reference : 11845
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 27-08-2025.
Wondom AA-AS32157
Amplifier Tripath TA2024 Class D 2 x 10W / 8 Ohm
Wondom AA-AS32157 Amplificateur Tripath TA2024 Class D 2x10W 8Ω
Wondom proposes here a TA2024 Clas D amplifier delivering a power of 2x10W under 8Ω, ideal for any secondary or auxiliary HiFi installation. Thanks to its compact design, its elegant case and its great ease of use, this amplifier will allow you to listen to your favorite songs on your audio systems with extreme simplicity. An excellent value for money, allowing you to drive various passive speakers 4Ω or 4Ω.
Product typeAmplifier
Amplification typeClass D
Amplification moduleTripath TA2024
Power2x15W @ 4Ω, THD+N < 10%
2x10W @ 8Ω, THD+N < 10%
Efficiency> 90% @ 8Ω
Input1x Stereo RCA
OutputSpeaker terminals (accept banana plugs)
Frequency response20Hz - 22kHz
SNR90dB
LED Status indicator
Volume control
ProtectionsOvercurrent
Overvoltage
Over heat
Power supply9-14VDC via Jack DC (power supply sold separately)
Housing materialAluminium
Dimensions120 x 74.6 x 49mm
Channel2 (Stereo)
Amplifier chipTA2024
Power (W)15
6 reviews
Excellent petit ampli à tarif imbattable
Excellent ampli avec une sonorité plutôt chaleureuse, un niveau de détail très correct (exceptionnel pour ce prix) et une capacité à driver des enceintes pas forcément faciles !
A associer à une alimentation permettant de fournir le courant nécessaire pour que l'ampli soit dynamique, comme la Huntkey HKA06012050-7C (que fournissait Audiophonics à une époque) ou la HKA06012050-7F.
Les alimentations linéaires, même assez puissantes, ne sont pas trop sa tasse de thé, la dynamique n'est plus là (peut-être serait-elle meilleure en ajoutant un supercap ?).
Testé avec succès sur des enceintes à haut et moyen rendement.
Attention également à l'étage d'entrée qui sature très vite avec des sources au niveau de sortie élevé ; il faut penser à baisser le niveau de la source dans ce cas...
This review has been posted for WONDOM AA-AS32157 Amplifier Tripath TA2024 Class D 2 x 15W / 4 Ohm
Excellente petite machine.
J'ai commandé ce petit ampli sur la foi de différents avis indépendants, et aussi parce que j'avais remarqué la musicalité du ta2024.
Je n'ai pas été déçu...
En fait, j'ai ensuite commandé un deuxième ampli en secours, tant le résultat m'a plu.
Puis, tout bien réfléchi, j'ai installé un ampli par canal, afin de solliciter au minimum l'alimentation.
Donc j'utilise le canal droit de chaque ampli.
J'ai mis une résistance de 100 Ohms sur chaque canal gauche, au cas où il lui viendrait des envies d'oscillations, les amplis en classe D détestent les boucles ouvertes en sortie.
Le passage en deux blocs mono m'a fait gagner à l'écoute sur pratiquement tous les paramètres. Pour le prix de ces deux minuscules amplis, je ne sais ce que je pourrais leur opposer.
Un seul petit reproche : l'un des amplis a son bouton de volume collé ou trop serré, et si je voulais - après la garantie - améliorer l'alimentation, ou la rénover, je ne peux pas ouvrir l'appareil, de peur d'endommager le codeur optique.
Si quelqu'un a une solution, je suis preneur...
Sinon, mes enceintes ont un rendement pas trop mauvais, avec 91 dB. J'imagine que les 81 dB des Kef 101 d'autrefois seraient moins à l'aise...
Là, dans une pièce de 25 M2, un volume confortable est atteint et même dépassé sans problème.
Merci pour ces magnifiques petites trouvailles !
Bon ampli
Bien construit et performant. Satisfait de mon achat. Reçu rapidement et bien emballé. Merci à audiophonics.
Excellent petit ampli, basique mais performant ! Chaudement recommandé
Sonorité clean et agréable, satisfait de ce petit achat :-)
Chez moi, petit ampli de secours, pour l'instant essayé en association avec un "The Preamp" de Musical Fidelity et des enceintes Rogers Ls2A/2 au rendement de 87db, il est bien assez puissant et s'en sort plutôt bien. Sa sonorité est clean et agréable, bien plus naturelle que les petits amplis au même prix que l'on trouve sur les grands sites marchands.
Satisfait de mon achat :-)
Wondom proposes here a TA2024 Clas D amplifier delivering a power of 2x15W under 4Ω, ideal for any secondary or auxiliary HiFi installation. Thanks...
