By buying this product you get 159 loyalty points
With the R-N1000A, Yamaha offers a versatile, high-performance connected amplifier with both analog and digital inputs. The R-N1000A features as well high quality components and optimized circuitry for accurate and musical sound reproduction.
The R-N1000A is based on the brand's Total Purity Audio Reproduction Technology (ToP-ART), ensuring optimal processing and transmission of the input signal, which remains low in noise and distortion. This particular architecture is based on a balanced design. This is combined with ART (Anti-Resonance and Tough) technology, which provides better damping and greater chassis rigidity. This design allows the R-N1000A to offer a rich sound reproduction.
Equipped with an ESS ES 9080Q 32bit 384kHz DAC, the R-N1000A offers great performance in terms of signal-to-noise ratio. This connected amplifier exploits all the advantages of high-resolution sound sources also thanks to Yamaha's exclusive network module. Yamaha's goal here with the R-N1000A is to reproduce the subtle ambience of concert halls with an extreme level of nuance and detail.
To eliminate power loss and audio signal degradation, the R-N1000A is equipped with large grounding cables. This is one of the features that make it a high-end product. For the amplifier section, a screw connection was adopted to reinforce the grounding. The result is a very clear sound.
Using only high-end electronic components specifically selected for their sonic performance, the R-N1000A manages to deliver exceptional sound reproduction.
To prevent signal loss, the R-N1000A features gold-plated connectors for its speaker terminals and input connections.
The R-N1000A's Pure Direct mode allows the audio signal to bypass all tone and balance control circuits. This ensures better sound quality while preserving the power of the amplifier. A method that allows for a transparent and musical reproduction.
The R-N1000A's front-panel Loudness function allows you to adjust the balance of high and low frequencies while preserving a full tonal range regardless of the volume level. This can be a useful tool for dealing with the natural loss of high and low frequencies at low sound levels.
The R-N1000A features Yamaha's MusicCast system, which enables it to support many music streaming services such as Spotify, Deezer, Tidal and Qobuz. So you can access all your music quickly and easily from your smartphone. The Yamaha amplifier is also compatible with AirPlay 2. So you can also stream your music via Apple Music.
This amplifier supports the majority of your music sources, allowing you to enjoy superior sound in many different usage scenarios.
| 1 | CD RCA input |
| 2 | 2x Optical inputs |
| 3 | Coaxial input |
| 4 | USB-B input |
| 5 | WiFi / Bluetooth antenna |
| 6 | Ethernet input (RJ45) |
| 7 | Service port (update) |
| 8 | HDMI ARC input |
| 9 | AC power input |
| 10 | 2x Line output (RCA) |
| 11 | Phono input (RCA) / GND |
| 12 | Pre-out (RCA) |
| 13 | Radio antenna connector |
| 14 | Trigger output |
| 15 | Subwoofer output (RCA) |
| 16 | Speaker terminals |
Enjoy the best of your TV. The HDMI ARC port allows you to connect directly to your TV to transmit a pure sound signal for excellent sound quality.
With the phono input of the R_1000A you can easily enjoy your turntable and your record collection.
Native DSD256 and PCM 384kHz playback are also supported, so you can enjoy exceptional sound quality that takes full advantage of high-resolution audio sources.
You can store up to 40 DAB/DAB+ digital radio stations.
| Specifications | |
| Product type | Connected amplifier |
| Network section | Supported file formats: MP3, WMA, MPEG-4 AAC, WAV, FLAC, AIFF, DSD AirPlay: Yes |
| Dynamic poweroutput | 2x 140W @ 8Ω 2x 170W @ 6Ω 2x 220W @ 4Ω 2X 290W @ 2Ω |
| Rated power | 2x100W @ 8Ω 2x1200W @ 6Ω |
| Frequency response | 10Hz-100kHz 0±1.0dB 20-20kz0±0.5db (Pure Direct) |
| Inputs | WiFi Bluetooth 3* RCA stéréo 1* Phono RCA 1* Coaxial 2* Optique Toslink 1* RJ45 1* USB-B 1* HDMI ARC |
| Outputs | Speaker terminals 1* Stereo RCA pre-out 1* RCA subwoofer output 1* Jack 6.35mm headphone output |
| Trigger output | |
| FM sensitivity 50dB (IHF, 1 kHz, 100 % mod., mono) | 3µV (20.8 dBf) |
| SNR FM | Mono: 69dB Stereo: 68dB |
| Pure Direct feature | |
| ToP-ART | |
| General | |
| Standby consumption | 0.1W |
| Dimensions | 435*151*395mm |
| Weight | 12.3kg |
| Color | Black |
| Input | Optical |
| Input | RJ45 |
| Input | WiFi |
| Input | USB |
| Input | SPDIF |
| Input | Bluetooth |
| Input | HDMI |
| Input | RCA |
| Output | Speaker terminal |
| Output | Subwoofer |
| Output | RCA |
| Output | Jack 6.35mm |
| Color | Black |
| Channel | 2 (Stereo) |
| Class | Class A / AB |
| Amplifier chip | ES9080Q |
| Power (W) | 220.0 |
| Remote Control | Yes |
