YAMAHA R-N1000A Amplifier Streamer ES9080Q Pure Direct ToP-ART 2x220W 4 Ohm 32bit 384kHz DSD256
With the R-N1000A, Yamaha offers a versatile, high-performance connected amplifier with both analog and digital inputs. The R-N1000A features as well high quality components and optimized circuitry for accurate and musical sound reproduction.
By buying this product you get 159 loyalty points
Reference : 17802
1 599,00 €tax incl.
1 332,50 € tax excl.
YAMAHA R-N1000A
YAMAHA R-N1000A Amplificateur Connecté ES9080Q 384 kHz/32 bits Pure Direct ToP-ART 2x220W 4 Ohm
ToP-ART technology
The R-N1000A is based on the brand's Total Purity Audio Reproduction Technology (ToP-ART), ensuring optimal processing and transmission of the input signal, which remains low in noise and distortion. This particular architecture is based on a balanced design. This is combined with ART (Anti-Resonance and Tough) technology, which provides better damping and greater chassis rigidity. This design allows the R-N1000A to offer a rich sound reproduction.
A high precision DAC for high performance
Equipped with an ESS ES 9080Q 32bit 384kHz DAC, the R-N1000A offers great performance in terms of signal-to-noise ratio. This connected amplifier exploits all the advantages of high-resolution sound sources also thanks to Yamaha's exclusive network module. Yamaha's goal here with the R-N1000A is to reproduce the subtle ambience of concert halls with an extreme level of nuance and detail.
Low impedance
To eliminate power loss and audio signal degradation, the R-N1000A is equipped with large grounding cables. This is one of the features that make it a high-end product. For the amplifier section, a screw connection was adopted to reinforce the grounding. The result is a very clear sound.
High-end components
Using only high-end electronic components specifically selected for their sonic performance, the R-N1000A manages to deliver exceptional sound reproduction.
Gold-plated terminal blocks
To prevent signal loss, the R-N1000A features gold-plated connectors for its speaker terminals and input connections.
Pure Direct mode
The R-N1000A's Pure Direct mode allows the audio signal to bypass all tone and balance control circuits. This ensures better sound quality while preserving the power of the amplifier. A method that allows for a transparent and musical reproduction.
Loudness feature
The R-N1000A's front-panel Loudness function allows you to adjust the balance of high and low frequencies while preserving a full tonal range regardless of the volume level. This can be a useful tool for dealing with the natural loss of high and low frequencies at low sound levels.
Un amplificateur connecté
The R-N1000A features Yamaha's MusicCast system, which enables it to support many music streaming services such as Spotify, Deezer, Tidal and Qobuz. So you can access all your music quickly and easily from your smartphone. The Yamaha amplifier is also compatible with AirPlay 2. So you can also stream your music via Apple Music.
Enjoy exceptional sound quality from all your audio sources
This amplifier supports the majority of your music sources, allowing you to enjoy superior sound in many different usage scenarios.
Complete connectivity
xxxYAMAHA R-N1000A Amplificateur Connecté ES9080Q 384 kHz/32 bits Pure Direct ToP-ART 2x220W 4 Ohm
1CD RCA input
22x Optical inputs
3Coaxial input
4USB-B input
5WiFi / Bluetooth antenna
6Ethernet input (RJ45)
7Service port (update)
8HDMI ARC input
9AC power input
102x Line output (RCA)
11Phono input (RCA) / GND
12Pre-out (RCA)
13Radio antenna connector
14Trigger output
15Subwoofer output (RCA)
16Speaker terminals
Many features
YAMAHA R-N1000A Amplificateur Connecté ES9080Q 384 kHz/32 bits Pure Direct ToP-ART 2x120W 6 Ohm
HDMI ARC input
Enjoy the best of your TV. The HDMI ARC port allows you to connect directly to your TV to transmit a pure sound signal for excellent sound quality.
Enjoy your vinyl records
With the phono input of the R_1000A you can easily enjoy your turntable and your record collection.
USB DAC function
Native DSD256 and PCM 384kHz playback are also supported, so you can enjoy exceptional sound quality that takes full advantage of high-resolution audio sources.
Tuner DAB/DAB+
You can store up to 40 DAB/DAB+ digital radio stations.
Product typeConnected amplifier
Network sectionSupported file formats: MP3, WMA, MPEG-4 AAC, WAV, FLAC, AIFF, DSD
AirPlay: Yes
Dynamic poweroutput2x 140W @ 8Ω
2x 170W @ 6Ω
2x 220W @ 4Ω
2X 290W @ 2Ω
Rated power2x100W @ 8Ω
2x1200W @ 6Ω
Frequency response10Hz-100kHz 0±1.0dB
20-20kz0±0.5db (Pure Direct)
InputsWiFi
Bluetooth
3* RCA stéréo
1* Phono RCA
1* Coaxial
2* Optique Toslink
1* RJ45
1* USB-B
1* HDMI ARC
OutputsSpeaker terminals
1* Stereo RCA pre-out
1* RCA subwoofer output
1* Jack 6.35mm headphone output
Trigger output
FM sensitivity 50dB (IHF, 1 kHz, 100 % mod., mono)3µV (20.8 dBf)
SNR FMMono: 69dB
Stereo: 68dB
Pure Direct feature
ToP-ART
Standby consumption0.1W
Dimensions435*151*395mm
Weight12.3kg
InputHDMI
InputRJ45
InputWiFi
OutputSpeaker terminal
OutputSubwoofer
OutputJack 6.35mm
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipES9080Q
Power (W)220.0
Remote ControlYes
With the R-N1000A, Yamaha offers a versatile, high-performance connected amplifier with both analog and digital inputs. The R-N1000A features as...
