YAMAHA R-N800A Amplifier Streamer ES9080Q Pure Direct ToP-ART 2x220W 4 Ohm 32bit 384kHz DSD256
With the R-N800A, Yamaha offers a versatile, high-performance connected amplifier with both analog and digital inputs. The R-N800A also features high-quality components and optimized circuitry for accurate and musical sound reproduction.
By buying this product you get 119 loyalty points
Reference : 17801
1 199,00 €tax incl.
999,17 € tax excl.
YAMAHA R-N800A
YAMAHA R-N800A Amplificateur Connecté ES9080Q 384 kHz/32 bits Pure Direct ToP-ART 2x120W 6 Ohm
ToP-ART technology
The R-N800A is based on the brand's ToP-ART (Total Purity Audio Reproduction Technology), ensuring optimal processing and transmission of the input signal, which remains low in noise and distortion. This particular architecture is based on a balanced design. It is also associated with the ART (Anti-Resonance and Tough) technology, promoting a better damping and a greater rigidity of the chassis. This design allows the R-N800A to offer a sound reproduction of a beautiful richness.
A high precision DAC for high audio performance
Equipped with an ESS ES 9080Q 32bit 384kHz DAC, the R-N800A offers great performance in terms of signal to noise ratio. This connected amplifier also exploits all the advantages of high-resolution audio sources thanks to its exclusive Yamaha network module. Yamaha's goal here with the R-N800A is to reproduce the subtle ambience of concert halls with a level of nuance and detail pushed to the extreme.
Low impedance
To eliminate power loss and audio signal degradation, the R-N800A is equipped with large grounding cables. This is one of the features that make it a high-end product. For the amplifier section, a screw connection has been adopted to strengthen the grounding. The result is a very clear sound.
Pure Direct mode
The R-N800A's Pure Direct mode allows the audio signal to bypass all tone and balance control circuits. This ensures better sound quality while preserving the power of the amplifier. A method that allows for a transparent and musical reproduction.
Loudness feature
The R-N800A's front-panel Loudness function allows you to adjust the balance of high and low frequencies while preserving a full tonal range regardless of the volume level. This can be a useful tool for dealing with the natural loss of high and low frequencies at low sound levels.
A connected amplifier
The R-N800A is both an amplifier and a network player, and features Yamaha's MusicCast system, which allows it to be compatible with many streaming services such as Spotify, Deezer, Tidal, and Qobuz. So you can access all your music quickly and easily via your smartphone. The Yamaha amplifier is also compatible with AirPlay 2. So you can also stream your music via Apple Music.
Enjoy exceptional playback quality from all your audio sources
This amplifier supports the majority of audio sources, allowing you to enjoy superior sound in many different usage scenarios.
Complete connectivity
1RCA CD input
22x Optical inputs
32x Coaxial inputs
4USB-B port
5Ethernet plug (RJ45)
6WiFi / Bluetooth antenna
7Service port (update)
8AC power plug
92x Line out (RCA)
10Phono input (RCA) / GND
11Pre-out (RCA)
12Radio antenna connector
13Trigger output
14Subwoofer output
15Speaker terminals
Many features
Enjoy your vinyls
With the phono input of the R_N800A you can easily enjoy your turntable and your record collection.
USB DAC feature
Native DSD256 and PCM 384kHz playback are also supported, allowing you to enjoy exceptional sound quality, making full use of high-resolution audio sources.
DAB/DAB+ tuner
You can store up to 40 DAB/DAB+ radio stations.
Product typeConnected amplifier
Network sectionSupported file formats: MP3, WMA, MPEG-4 AAC, WAV, FLAC, AIFF, DSD
AirPlay: Yes
Dynamic power output2x 140W @ 8Ω
2x 170W @ 6Ω
2x 220W @ 4Ω
2x 290W @ 2Ω
Rated power output2x 100W @ 8
2x 120W @ 6
Frequency response10Hz-100kHz 0±1.0dB
20-20kH 0±0.5dB (Pure Direct)
Inputs1* Phono RCA
3* Stereo RCA
2* Optical Toslink
2* Coaxial
1* USB-B
1* RJ45
WiFi
Bluetooth
OutputsSpeaker terminals
1* Stereo RCA pre-out
1* Subwoofer RCA output
1* Jack 6.35mm headphone output
Trigger output
FM 50dB sensitivity (IHF, 1 kHz, 100 %mod., mono)3µV (20.8dBf)
SNR FMMono : 69dB
Stereo: 68dB
Pure Direct feature
ToP-ART
Standby consumption0.1W
Dimensions435*151*395mm
Weight11.4kg
InputWiFi
InputRJ45
OutputSpeaker terminal
OutputSubwoofer
OutputJack 6.35mm
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipES9080Q
Power (W)220.0
Remote ControlYes
With the R-N800A, Yamaha offers a versatile, high-performance connected amplifier with both analog and digital inputs. The R-N800A also features...
