IAN CANADA TRANSFORMER I/V Passive I/V Stage Module
The Ian Canada Transformer I/V is an I/V transformer module operating in purely passive mode, without any feedback or active components. It doesn't even need a power supply. This module makes it possible to design an excellent, low-cost DAC.
Reference : 18971
119,00 €tax incl.
99,17 € tax excl.
Last items in stock !
Shipping date: 13-05-2026.
Ian Canada Transformer I/V Passive I/V Stage Module
Unlike OPA-based I/V solutions, the Transformer I/V offers a natural, analog sound.
Key features:
  • Audiophile-level sound quality at an affordable price.
  • Unbalanced (RCA) and unbalanced (XLR) outputs. All output connectors are located on the same side of the module.
  • Custom high-performance audio transformers included/assembled 15Hz-30kHz +/-0.3dB.
  • Output levels 0dB. XLR: 4Vp-p RMS; RCA: 2Vp-p RMS.
  • Pure passive mode with no feedback and no active components.
  • No power supply required. Simplifies system set-up.
  • Ready-to-use module, no soldering required.
  • Works directly with ES9038Q2M and ES9028Q2M DAC HAT modules.
  • High-precision, low-noise metal-film I/V resistors from the Vishay/Dale CMF55 range.
  • Power LED to indicate DAC operating status.
  • Grounding jumper.
Product typeI/V stage module
InputPCB Connector
Max sampling rateNC
Interface chipNC
2 reviews
Bonne config
L'ensemble
- Dual Mono MKII DAC ES9038Q2M.
- Transformer I/V étage passif.
- Monitor Pro contrôleur.
Apporte un plus vraiment agréable dans ma configuration.
Bien brancher le monitor sur le GPIO du DAC et mettre le volume à 0db… sinon par défaut il est à -40db et donc pas de son.
This review has been posted for IAN CANADA TRANSFORMER I/V Passive I/V Stage Module
Great Audio stage that allows you to play digital music with the sweetness of analog. I am very satisfied
The Ian Canada Transformer I/V is an I/V transformer module operating in purely passive mode, without any feedback or active components. It...
