IBASSO IT04 In-Ear Monitor IEMHigh-End Quad Diaphragm 16 Ohm
The iBasso IT04 in-ear headphones are positioned in the high-end segment of the audiophile world, with an exceptional design. A design that impresses on paper but is above all at the service of sound to offer a detailed, rich, immersive listening, for a journey towards new musical horizons.
Reference : 13267
499,00 €tax incl.
415,83 € tax excl.
iBasso IT04
iBasso IT04 IEM 4 drivers high end
Insérer texte alternatif ici
Dynamic Driver with Graphene Diaphragm
The dynamic bass driver is developed directly by iBasso. It uses a magnetic flux close to 1T with a graphene membrane. This design allows the IT04 to deliver both deep and incredibly accurate bass.
Knowles Triple Knowles
For the realization of these IEM IT04, iBasso associated with the Knowles designer, specialized in the manufacture of loudspeakers. As a result, IT04s use no less than 3 Knowles drivers using Balanced Armature technology to cover treble and midrange with high accuracy. This technology uses an electronic signal to vibrate a very thin reed placed between two magnets. The movement of this reed is then transmitted to an extremely stiff aluminium membrane. This system makes it possible to suppress resonances to obtain exceptional precision. In addition, this technology makes it possible to obtain light and very small drivers, ideal to associate them with other loudspeakers, including in very small housing. Drivers perfectly matched with the Crossover filter designed and precisely tuned by iBasso.
Une conception interne au service d'une restitution incroyable
Les IT04 impressionnent de par leur conception interne pensée pour délivrer un son d'une justesse incroyable. Ce design breveté intègre ainsi pas moins de 4 drivers : 3 haut-parleurs Balanced Armor conçus par le spécialiste Knowles, ainsi qu'un driver dynamique. Les trois driver Knowles correspondent à un Tweeter, un Tweeter-Médium et un Médium. Le driver dynamique lui est là pour restituer avec une grande profondeur les graves. Cet assemblage s'apparente sans conteste à une enceinte HiFi complète, miniaturisée pour vous accompagner tout au long de la journée.
iBasso IT04 IEM 4 Drivers
Câble CB12 Argent Cuivre détachable MMXC Jack 2.5mm
Câble CB12 détachable
Si les écouteurs en eux mêmes profitent d'une excellente conception, le câble qui les accompagne n'est pas en reste. Il s'agît en effet du câble iBasso CB12 symétrique, composé de conducteurs mono cristal en Argent et en Cuivre 8 brins plaqué Argent. Côté connecteurs on retrouve d'une part un Jack 2.5mm TRRS plaqué Or et d'autre part des MMXC également plaqués Or. On retrouve dans le package un adaptateur Jack 2.5mm TRRS vers Jack 3.5 TRS permettant aux IT04 de fonctionner comme des écouteurs asymétriques.
Ergonomie
Les IT04 s'inspirent du design et de la forme des IT03 pour offrir un grand confort à l'utilisation, y compris durant de longues heures, ainsi qu'un maintien efficace. Malgré une un design interne plus que complet, les IT04 s'avèrent très légers avec seulement 13g affichés à la balance. Les IEM présentent également une esthétique tout en finesse avec une plaque en fibre de carbone et une finition brillante et lisse.
Package
iBasso IT04 Package
Type de produitIEM (écouteurs intra-auriculaires)
Réponse en fréquence5Hz - 40kHz
Sensibilité110dB +/-2dB
Impédance16 Ohm
Atténuation du bruit-30dB
Puissance10mW
THD< 1% @ 1kHz/1mW
ConnectiqueJack 2.5mm
Longueur du câble1.2m
Poids13g
Package1x iBasso IT04
1x Housse de transport en cuir
1x câble CB12 Jack 2.5mm MMXC
1x Adaptateur Jack 2.5mm vers Jack 3.5mm
3 reviews
iBasso IT04
J'ai associé ces écouteurs au lecteur iBasso DX220.
Tous mes fichiers sont au format ALAC.
Mes genres musicaux vont du classique au rock en passant par la chanson française.
Je peux vous assurer que tout le spectre
est reproduit de manière claire est précise.
C'est en tous points parfait !
This review has been posted for IBASSO IT04 In-Ear Monitor IEMHigh-End Quad Diaphragm 16 Ohm
Excellentissime !
Bonjour,
Je recommande les yeux fermés ces intras de milieu de gamme dont la qualité sonore rivalise avec les hauts de gamme qui coûtent le double du prix !
Parfait je recommande
Bonjour,
J'ai couplé cet intra avec mon IBasso DX80 pour l'écoute de fichiers exclusivement de format FLAC ou APE.
Quelle claque ! La spatialisation est phénoménale, équilibre des basses présentent juste ce qu'il faut parfaitement rondes et claires, les aigus sont bien présents mais pas du tout agressifs et les médiums se font bien sentir. La réstitiuon des voix et des instruments accoustiques est très précises, les percussions percutent, il semble qu’aucun détails ne manque cela rend hommage au temps passé au mixage et au mastering.
J'écoute du Métal, de l'Electro Rock, de l'Industiel, du Jazz, du classique..... Bref tout un échantillon musical qui permet de se faire une idiée assez précise du potentiel de ce produit.
Je suis tout de même un peu embêté car je redécouvre chaque album et suis donc obligé de reparcourir toute ma ‘’musithéque’’ 400G en tout je vous laisse imaginer.
Un produit qui pour le prix est, à mon avis, comparable à d’autres beaucoup plus cher. Pour finir il n’y a pas d’hésitation à avoir c’est un très bon investissement.
The iBasso IT04 in-ear headphones are positioned in the high-end segment of the audiophile world, with an exceptional design. A design that...
