In-Ear Monitors IEM Dynamic 10mm 120dB 28 Ohm 20Hz-20kHz
Moondrop unveils with the Chu in-ear earphones taking advantage of a very nice design quality and sound reproduction at an exceptionally affordable price. Each IEM features a 10mm diameter dynamic driver with a Nano-Crystal coated composite membrane, decentralized in an acoustically optimized cavity. These drivers are powered by a motor using a N52 neodymium magnet and an ultra-thin CCAW coil, ensuring excellent efficiency and delivering a sound reproduction as dynamic as rich in details, while remaining faithful to the original signal. The robust Chu headphones have a beautiful die-cast metal body. The eartips eliminate unwanted resonances thanks to a particularly studied structure, significantly reducing the linear distortion of the high frequencies and supporting a natural timbre, while offering a very good comfort of port, adapting perfectly to the shape of the ear.
| Specifications | |
| Product type | In-Ear Monitors (IEM) |
| Driver type | Dynamic 10mm |
| Diaphragm | Composite, titanium-coated |
| Magnet | Neodymium N52 |
| Voice coil | CCAW 0.035mm |
| Body material | Zinc alloy |
| Sensitivity | 120dB/Vrms @ 1kHz |
| Impedance | 28Ω ±15% @ 1kHz |
| THD | ≤ 1% @ 1kHz |
| Effective frequency response | 20Hz - 20kHz (IEC60318-4, -3dB) |
| Connector | Jack 3.5mm |
| Color | Black |
| Impedance (Ω) | 28 |
| Efficiency / Sensitivity (dB) | 120.0 |
| Lowest frequency (Hz) | 20 |
| Highest frequency (Hz) | 20000 |
