In-Ear Monitor IEM Hi Res 16 Ohm
Shanling's ME100s are high quality IEMs offering a surprising sound reproduction of precision and sound details. These are equipped with high-end components with double composite diaphragms and OFC copper conductors. Their ergonomic design allows the earphones to be held effectively.
The ME100s include a moving coil with composite diaphragm and double magnetic double chamber. This design allows to obtain a magnetic induction of more than 1T, a higher efficiency, a high performance transient response, a low impedance, a high sensitivity. In this way, ME100s can be combined with the vast majority of audio devices, including smartphones, while taking advantage of the CCAW coil to improve mid-range and high-frequency performance.
To provide transparent sound reproduction and deep low frequencies, Shanling ME100s are equipped with innovative membranes. These are 10mm composite diaphragms made of Polyurethane (PU) and Polyetheretherketone (PEEK).
The cable supplied with the ME100 in-ear monitors is particularly well designed. It integrates 8 very high purity OFC copper conductors, allowing to maximize the cable conductivity and therefore the audio performance. It reduces distortion and signal loss.
The headphones have MMCX connectors to replace the cable or upgrade to an even more efficient model. MMCX is a common format in the EMI world and there are many cables if the need or desire to change cables arises.
For its structure, the ME100 uses an extremely robust aluminium alloy. The material used and the internal design of these headphones make it possible to reduce harmonic resonances while promoting the reproduction of midrange and bass.
After being machined and polished via CNC, the earphone body is anodized and undergoes precision operations by hand. The body also includes a tempered glass part. The whole system creates a stylish and assertive look, while maintaining a high level of comfort in use. This efficient design also provides better insulation and reduces external noise.
The ME100s have received Hi-Res certification from the Japan Audio Society, thanks in particular to the wide frequency band that these headphones are capable of delivering. Indeed, the latter are capable of exceeding 40kHz, while ensuring low distortion and clear sound.
The earphones are delivered in a beautiful leather case with velvet interior, effectively protecting them from dust, shock and vibration. The package also includes a set of interchangeable tips. Several designs are available to adapt to each morphology but also to benefit from a different sound reproduction, by promoting the diffusion of certain frequencies.
| Specifications | |
| Product type | IEM |
| Connector | Gold plated 3.5mm |
| Cable length | 1.3m |
| Cable conductor | OFC Copper |
| Impedance | 16 Ohm |
| Sensitivity | 111dB +/- 3dB |
| Frequency response | 20Hz - 40kHz |
| Weight | 5g |
| Color | Black |
| Impedance (Ω) | 16 |
| Efficiency / Sensitivity (dB) | 111 |
| Lowest frequency (Hz) | 20 |
| Highest frequency (Hz) | 40000 |
