xDuoo EP1 In-Ear monitors Ceramic Body 10mm Diaphragm 108dB 16Ohm Black
Reference : 12273
24,90 €tax incl.
20,75 € tax excl.
xDuoo Ep1 intra-auricular audiophiles
Xduoo ep1
xDuoo has designed the EP-1 in-ear for a single purpose: Bring the best isolation and reproductive quality at a democratic price.
Agile in any situation
Xduoo ep1
Produced in an extruded aluminum casing, the xDuoo EP1 produces a high readability sound with 10mm diaphragm professsionel diaphragms offering increased capacity in the bass.
Attention for every detailxduoo EP1
This in-ear headset features an "anti-twist" 5-way, 32-strand OFC copper cable. Due to its struture this cable does not knot in a pocket or in a bag. Its 16 ohm impedance makes it compatible with a wide range of smartphones and especially with iPad and iPhone tablets.
Connectivity and listening comfort
xduoo EP1
The Xduoo EP1 features two classic memory foam tips and three silicone earpieces that perfectly fit your ears for optimal isolation from outside noise. Its gold-plated-gold connector provides high-fidelity audio with a 108dB output for ultra-dynamic listening.
xduoo EP1
Technical featuresc
TypeIntra Auricular
HeadphonesAluminum factory CNC
MembranesLow distortion 10mm
Permissible power10mW
Pressure level108dB / mW
Bandwidth10Hz - 20kHz
Nominal impedance16Ω over 1kHz
Weight of each earpiece4g
Cable length1.2m
Miscellaneous
Total weight16g
Impedance (Ω)16
Efficiency / Sensitivity (dB)108
Lowest frequency (Hz)10
Highest frequency (Hz)20000
3 reviews
Excellent !
C'est mon 1er achat sur la boutique Audiophonics, par l'intermédiaire d'un célèbre site de vente aux enchères.
Le but était de remplacer les casques intra fournis avec mes smartphones successifs, avec un petit budget.
Résultat, je redécouvre ma musique et réutiliser es anciens écouteurs s'apparente maintenant à une torture.
Précisions : je lis des fichiers lossless sur un vieux Fiio X1.
Hormis l'écoute, j'ai également apprécié le fil qui ne s’emmêle pas, le choix des embouts et la qualité ressentie de ce produit.
Tout ça pour un prix plus que raisonnable.
Je suis enchanté, merci !
This review has been posted for xDuoo EP1 In-Ear monitors Ceramic Body 10mm Diaphragm 108dB 16Ohm Black
Parfait pour le quotidien
A ce prix à il est impossible d'avoir mieux, livré en plus avec tous les adaptateurs nécessaires. Parfait pour le quotidien !
Ecouteurs de bonne facture
Bonne sonorité dans l'ensemble avec un grand choix d'embouts,
a recommander.
