This 3.5mm jack socket has 3 poles and therefore works with TRS jacks. Ideal for PCB mounting as part of a DIY project, this socket will enable you to transmit a stereo or balanced mono signal. Its silver-plated contacts ensure a high level of conductivity and resistance to corrosion and oxidation.
| Specifications | |
| Product type | Jack Socket |
| Pole numbers | 3 |
| COntact matérial | Copper Alloy |
| COntact plating | Silver |
| Rated voltage | 12V |
| General | |
| Color | Black |
| Package | 1x Female 3-pole Jack 3.5mm Socket |
| Max cable diameter (mm) | N/A |
| Mounting type | To weld |
| Connectic | Female |
| Contacts number | 3 |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Silver |
