Max cable diameter (mm)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
2 - 3
Mounting type
Jean-François D.
Impeccable !
Vasilios K.
Ça Chauffe !
Jack 6.35mm
Discover our range of 6.35mm jack connectors for the design of your analog audio cables.
