SHANLING ONIX XB0 3.5mm Male to 4.4mm Female Jack Adapter
The Shanling XB0 adapter converts a 3.5mm jack output to a 4.4mm balanced format, enabling differential signal transmission that limits ground interactions while improving measured performance parameters such as harmonic distortion, signal-to-noise ratio and dynamic range, resulting in more stable reproduction and improved channel separation.
Reference : 22112
29,91 €tax incl.
24,92 € tax excl.
Shanling Onix XB0 3.5mm Male to 4.4mm Female Jack Adapter Gold Plated
SHANLING ONIX XB0 : Front view
The Shanling XB0 adapter converts a 3.5mm jack output to a 4.4mm jack balanced format, enabling differential signal transmission that limits ground interactions while improving measured performance parameters such as harmonic distortion, signal-to-noise ratio and dynamic range, resulting in more stable reproduction and improved channel separation.
Product typeJack adapter
Input1x 3.5mm male jack
Output1x 4.4mm female jack
Connector platingGold
Housing materialAL6061 aluminum
CompatibilityOnly ONIX Waltz XM10 LTD
Dimensions20 x 11 x 10.5mm
Weight5.7g
ColorCopper
PackageSold by unit
ConnecticMale & Female
ConnectorJack 4.4mm
ConnectorJack 3.5mm
SHANLING ONIX XB0 3.5mm Male to 4.4mm Female Jack Adapter Gold Plated
The Shanling XB0 adapter converts a 3.5mm jack output to a 4.4mm balanced format, enabling differential signal transmission that limits ground...
